Question about Samsung SGH-D900 Cellular Phone
I have a sumsung cell phone. It came without instructions, and I have no idea what a "soft key" is. It is about 3 inches long and 2 inches wide and fold in half. I am trying to learn how to text but a picture would help!
  • 492 Answers
On a flip phone the left and right soft keys are under the display when you open the phone. We used to call them "snake eyes" back in the day. Usually they access the menus on the handset. Each of the other keys on the keypad correspond to letters of the alphabet just like the letters on your home phone. Pressing 2 key once for "a", twice for "b", etc.
Posted on Mar 22, 2011
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
Jan 05, 2012 | Nokia 5700 Cellular Phone
Tip
How to Reboot a Blackberry Without Removing the Battery?
If you remove batteries and hardware while tinkering with electronic devices, you might run into trouble down the line. Blackberry devices must be rebooted time and again, but you can reboot your Blackberry without removing the battery. <br /> <b><i>Instructions</i></b> <br /> 1. When you install a new program or have a system failure, you must reboot the Blackberry. This is the same concept used in larger desktop or laptop computers. 2. Hold off on using the new program by selecting "Later" instead of "Now" when you are prompted by the Blackberry. This will allow you to wait awhile to reboot your device, especially if you need to use it at the moment and can put off the new program installation. 3. Initiate what is known as a soft reboot by pressing and holding down the key combination of Alt+Cap+Backspace on the Blackberry keyboard. Using this method will also work when the device stalls and you see only the white arrow, but it refuses to move. 4. Note that certain Blackberry models are different and require you to press and hold the Alt+Cap+Delete key combination to reboot the Blackberry without removing the battery. Make sure your keypad is correct for using this method of soft reboot before attempting it. Blackberry makes several different models, and they all operate differently under soft-reboot conditions. 5. Reference your Blackberry manual. Make sure that the keypad soft reboot will work with the specific model you are using. Larger models are typically more prone to working with the aforementioned soft reboot. If this does not work, you will have to use a secondary method. 6. Check to see if you need to install an application for your phone that allows for a soft reboot. Many models, like the Pearl, allow you to download an application for soft reboot. These applications may prevent you from pulling the battery to reboot. 7. Try all the available methods, and if it still does not work, request assistance from your Blackberry dealer. She may know of an alternative or a firmware update for your device. <br />
on Jun 06, 2011 | Cell Phones
We bought KX-TG4024 cordless telephones. Can the ring tone be changed?
I have a similar model and the ring tone can be changed.
To change on the Handset
1, Press Menu
2, Scroll using arrow up/down key- go to "Ringer setting" then press soft key Select.
3, Scroll to "Incoming call" then press soft key Select
4, You can scroll to "ON/OFF or 2".. Maybe your phone has more choices. Number 2 will be a different ring tone.
5, Press soft key "Save" then press OFF key.
The Base Unit
1, Press Menu
2, Scroll using up/down arrow keys to "Initial setting" press soft key Select
3, Srcoll to "Set base unit" press soft key Select
4, Scroll to "Incoming call" press soft key Select
5, select ON/OFF or 2 with arrow keys
6, Press soft key "Save" then press OFF key.
I hope this has been helpful..
Aug 29, 2011 | Panasonic Cell Phones
There is a red line through one of my contacts and when that person calls, it goes right to voicemail without ringing
Give this a try:
  1. From the standby screen, press the right soft key for Menu
  2. Select Address Book (8)
  3. Select Reject List (5)
  4. Highlight the desired entry, using the navigation keys
  5. Press the left soft key for Options
  6. Select Delete (2)
  7. Choose Selected (1)
  8. Press the left soft key for Yes to confirm the deletion of the Reject List entry
Jun 28, 2011 | Samsung Propel A767 Cell Phone
I forgot my phone password for my HTC S621 that I haven't used in 2 years. Is there a way to reset it?
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
or
With the phone on
Select Start> Accessories> Clear Storage> enter reset code default is 12345> Select YES.
May 24, 2011 | Cell Phones
My screen has stopped working, on my Samsung sgh-z720v and i need step by step instructions to copy contacts from phone to sim 'blind'
I had to do this for my old phone! here's the steps!
1. While in standby mode, press the left soft key for Menu
3. Select Contact List (1)
9. Select Copy (3)
10. Select SIM (2)
11. Press the left soft key to Save.
Mar 31, 2011 | Samsung SGH-Z720 Cellular Phone
How to check wap profile in my s3500 mobile?
1. Press 'Menu' (Navi key).
2. Highlight the 'Settings' and 'Select' (left soft key).
3. Highlight 'Application settings' and 'Select' (left soft key).
4. Highlight 'Browser' and 'Select' (left soft key).
5. Highlight 'Browser profiles' and 'Select' (left soft key).
6. press 'Options' (left soft key).
7. Highlight 'Add new connection' and 'Select' (left soft key).
Nov 11, 2010 | Samsung S3500 Cell Phone
Need to reset samsung reclaim sprint to factory setting
1.Reset to the default settings:
-From the carousel's Home tile, press the OK button for Menu
-Select Settings
-Select More (7)
-Select Security (12)
-Enter the User Lock Code (last 4 digits of phone number)
-Select Erase/Reset (3)
-Select Default Settings (0)
-Press the left soft key for Yes to confirm
-Press the left soft key for Yes again to confirm
2.Permanently delete all data and reset:
-Select Settings
-Select More (7)
-Select Reset Phone
-Press the left soft key for OK to confirm
After resetting your Samsung Reclaim M560, you will miss all data, so you should back up the necessary data first.
Oct 18, 2010 | Samsung Reclaim Cell Phone
Hard reset sumsung D980
Samsung (Most models)
IMEI number: * # 0 6 #
Software version: * # 9 9 9 9 #
Albo* # 0 8 3 7 #
Net Monitor: * # 0 3 2 4 #
Changing LCD contrast: * # 0 5 2 3 #
Memory info: * # 0 3 7 7 #
Albo * # 0 2 4 6 #
Reset CUSTOM memory: * 2 7 6 7 * 2 8 7 8 #
Battery state: * # 9 9 9 8 * 2 2 8 #
Alarm beeper: * # 9 9 9 8 * 2 8 9 #
Vibra test: * # 9 9 9 8 * 8 4 2 #
Oct 11, 2010 | Samsung SGH-D980 Cell Phone
How do i format my sd card via bluetooth
I'm sorry but u have to manually format ur memory card using the phone or a computer...
back up ur files first...
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located on the left side
  2. From the standby screen, press the right soft key for Menu
  3. Select My Stuff (7)
  4. Highlight the On Card tab, using the left or right navigation keys
  5. Highlight either Audio, Graphics or Videos, using the navigation keys
  6. Press the left soft key for Options
  7. Select More (4)
  8. Select Memory Card Settings (2)
  9. Select Format (2)
  10. Press the left soft key for Yes to confirm formatting the microSD Memory Card
  11. If prompted to rename, press the left soft key for Save
Dec 14, 2009 | Samsung Propel A767 Cell Phone
Samsung SGH-D900 Cellular Phone Logo
57 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
