Question about Mr. Heater Natural Gas Garage Heater - 45,000 BTU
I have a mr heater 75000 with a 4 flash blink code. the heater is brand new, only worked for 3 days. i have bypassed the 2 switches but still cant clear the 4 flash blink code.
    Brigadier General:
  • 4,736 Answers
According to the Owners/Installation Manual, the 4 flash blink code indicates that the High Limit or Roll Out Switch is open. This may be caused by a venting problem or high altitude operation. make sure you have the proper pressure to the heater's regulator. For Natural Gas it must be a continuous 7 water column inches.
For further information, I have included a link to your Owners Manual that you can download and print, for future reference. http://www.mrheater.com/upload/newsletter/MHU_HSU_CUH_60016_BL.pdf
Hope this helped to solve your problem.
Posted on Mar 22, 2011
I have a 2011 Toshiba 55 55SL417Uand the picture wont come on the green flashes 3 times pauses 3 flashes pause over and over
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 21, 2015 | Toshiba 55 55SL417U LCD TV
I have a 75000 kerosine heater that only runs a few min and shuts off and the led has a steady flash, (high limit switch open circut)
Jump the 2 yellow wires together if it stays running replace high limit switch under hood against the chamber
Feb 18, 2013 | Mr. Heater MH75KT
How do I bypass the tip over safety switch on my mr heater propane heater . I only use it for golfing in a golf acrt and no inside use.But it keep s going off when it s moved or bumped
I had the same peoblem you 1.remove the 6 screws 3 on eacb side 2.remove back panel 3.remove the tip over switch attached to bottem right looks like a black plugin4.hook the 2 wires that was connecting saftey swith togetber and tape them together with electrical tape (making sure they are touching obviously)5. Reassamble and your good to go no more constant relighting
Jan 07, 2012 | Mr. Heater Mr Heater Portable Buddy...
My heater is brand new and worked for 3 days. i have no heat, i also have 4 flashes blink code. indicates high limit/ rollout switch. i have rechecked the thermastat, gas line and the vent pipe, the fan...
There is something else that is causing the Overload/Roll Over Switch to trip. You can try unplugging the unit from it's electrical source and wait 30 minutes before plugging it back in. That may allow it to reset itself. Unfortunately the Overload/Roll Over Switch is preset at the factory and is not adjustable.
If the unit resets itself and starts working again, but then shuts down, check your Owners Manual for other causes. If you've misplaced your Owners Manual, here's a link to it, that you can download and print.
http://www.heaterstore.com/images_templ/mr-heater-heaters-mhu45-75lp-ng.pdf
Hope this helps to get you headed in the right direction. If all else fails, call the Technical Service Dept at the number listed in the Owners Manual.
Mar 03, 2011 | Mr. Heater MHU75NG
Mr heater 75000 btu thermostate turned up exhaust air turns on and ignitor doesnt ignite and times out
Probably your ignitor is bad...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 23, 2011 | Mr. Heater Natural Gas Garage Heater -...
My heater is in lockout according to the 2 flash code I'm seeing. My tank is half full so I no it's not a supply problem, and it has worked in the past. It tries to fire but it won't stay lit. It will go...
clean the flame censor check connection from sencor is tight, try jumping out the limit switch high leval , or the pressure switch see if it lights then
Jan 16, 2011 | Mr. Heater MHU45LP
As soon as i hook up the thermostate it flashes the 3 flashes code and i have already tryed a new thermostate .... as soon as i unhook the thermostate it flashes for normal operation with no call for heat...
Try using it without the thermostat, tie the two thermostat wires together or put a jumper between
r and w. If furnace operates, you must have wrong style of thermostat
Jan 28, 2010 | Mr. Heater Natural Gas Garage Heater -...
Mr heater 75,000 btu kerosene heater
HLS should stand for high limit switch(control) this model does show one in the parts diagram.
Feb 27, 2008 | Mr. Heater MH75KT
Open Questions:
See all Mr. Heater Natural Gas Garage Heater - 45,000 BTU Questions
Mr. Heater Natural Gas Garage Heater - 45,000 BTU Logo
429 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
