Question about Samsung BL103 Digital Camera
I have an 8G SD card with 2388 pics on it but my camera says no images.I want to delete all images but it says no images.
  • kakima Mar 22, 2011
    What happens if you format the card in the camera? If you want to delete all your pictures, formatting is the easiest way. In fact, memory cards should be formatted each time you finish downloading your pictures. FixYa is full of people asking how to salvage cards that haven't been formatted regularly.
    Brigadier General:
  • 11,967 Answers
If you've downloaded the pics you want to save to your computer and all you want to do now is delete all the pics from the card, just format it in the camera.
Posted on Mar 22, 2011
HOT TO DELETE ALL PIC ON FROM SD CARD
You can use the "Format Memory Card" option under the "Setup Menu" to delete all images on the Memory Card at a time.
Jan 22, 2011 | Nikon COOLPIX P5100 Digital Camera
How do i erase pics on sd card in camera?
With the switch in 'Viewing Mode', press the Delete button, which may give the option to delete one image or all, or press the Menu button and navigate to 'Format Memory Card'
Dec 11, 2010 | Cameras
How do i get the pictures from my camera to the memory card
the question I ask is why would you want to do this?
The camera has XX Mb of memory in case the card becomes full. Generally one downloads the pics on to a PC and deletes the Camera files to start again
If you want to keep the pic files in memory and save them tpo your pc. remove the card for safety.. Interrogate your camera via the connection cord and the software it came with. Download the folder with the pics in memory to your PC. Then delete the files on the camera. Insert the SD card and In menu, set up to save files to SD card rather than memory while there is space.
Please rate my help++++Thanks fore using FIXYA
Apr 16, 2010 | Samsung L200 Digital Camera
Kodak easy share wont delete or scan to the left to view pics
In order to solve the problem you need to transfer pictures from the internal memory to the SD card and thereafter you will be able to delete the pics in the internal memory.
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
  6. When you have finished copying pictures, reset the Image Storage location to your original setting.
Dec 22, 2009 | Kodak EasyShare CX7300 Digital Camera
Can't take or delete pictures.
Pull out the sd card and slide the lock to other position use link to look at pic.
http://www.pocket-tunes.com/images/kb/SD%20card%20lock%20slider.jpg
sometime the lock gets moved from normal handiling.
Sep 26, 2009 | Canon Powershot SX110 IS Digital Camera...
I turn on my camera and it states "memory card error", and I don't want to lose my pictures I have stored on it. Is there a way to recover the pics without reformatting and deleting the pics?
Have you tried connecting the SD card to the PC?
Make sure you can do that, Also, After you transfer them off, Make sure the slot the SD card fits into isn't dusty, and, If it still doesn't function, Re-Format the card after you've taken the images off.
Aug 20, 2009 | Canon PowerShot A590 IS Digital Camera
Up loading pics
The camera comes with software, if you cannot find the disk, you can download it from here:
http://www.canon.ca/inetCA/en/serviceDetail/method/load/id/1/sid/50/mid/2000029/type/D/opt/1
Download this manual
http://gdlp01.c-wss.com/gds/4/0900001034/01/DCSDV30_EN.pdf
Read pages 16 - 20, they explain all about different methods of downloading all images, just new images or even selecting specific images.
Mar 03, 2017 | Canon PowerShot SD750 / IXUS 75 Digital...
Not able to 'delete' a picture from my Lumix TZ3
Sounds like a MobileMate quirk Tanya. Use your USB cable connection to your PC/Camera interface and delete pics that way too see if this funny goes away.
If it does, and I believe it will, then it is a SanDisk issue not revising the File Allocation Table(FAT) after deleting the Pic File on the mem card.
You could also find out if this is just an SDHC SD card reader issue by using an older less dense standard 1 or 2Meg non-SDHC mem card in the reader and see if issue goes away.
The fallback of course to view and delete the pics on the camera before download, or download pics then note which pic file numbers you want deleted after viewing on PC, then put SD card back in camera and delete them there.
Another option for trial, is to cut and paste the whole DCIM folder, or sub pic folder to your PC from off the SD card using the card reader. The camera automatically generates subfolders under the DCIM folder if you completely remove(deleting by a cut or move), when you take your first picture on a camera with a DCIM but not sub pic folder. Try this first and I think you will find all pics will be deleted from camera that are in a subfolder under DCIM. If not, then cut or move the whole DCIM folder and create a new DCIM(empty) folder on the SD card using the PC and card reader. Of course using this method you cannot selective delete individual pics from the mem card. You would be deleting them all after the Folder cut or move from the SD card.
Dec 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Samsung BL103 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
