Question about Logitech 9312160403 Mouse
I want to mouse to be more sensitive when moving left and right
    Problem Solver:
  • 9 Answers
For any mouse, you can set this using (WinXP):
Control pannel -> Mouse -> Pointer Options tab -> Motion (Slow -> Fast)
Posted on Mar 22, 2011
How do i alter sensitivity for ASUS K601J inbedded mouse
Go to start, control panel, mouse. Here you can change your mouse settings to whatever you want - be it sensitivity or left-hand/right hand mouse.
P.S. If you are in category view in control panel, switch over to classic so you can have direct access to mouse settings.
Feb 23, 2013 | ASUS Computers & Internet
Logitech mouse right click too sensitive
Your computer mouse has preferences to make it easier to use. You can change the style and of the pointer, and you can change the sensitivity, which controls how easy or difficult it is to scroll across the screen. Speeding up the mouse sensitivity can allow you to move your cursor across the computer screen faster, while slowing it down can give you better control but you may have to move the mouse a greater distance to get your cursor to where you want it.
Click the Windows "Start" menu and type "mouse" into the Search field. Click on the "Change Mouse Settings" link in the search results. Click on the "Pointer Options" tab. Move the Motion slider bar to the right for a faster speed and to the left for a slower speed. Click "Apply" to apply the settings. Move your mouse to see if those are the settings you would like. If not, adjust the slider bar again. When you find the right setting for you, click "OK" to save the settings and close the window.
Jan 23, 2013 | Logitech Wireless Keyboard & Wirelss Mouse...
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
Cursor is jumping all over the screen before you can point at what you need - Dell D620 - Windows xp pro
Firstly try a different mouse to find out if the mouse is the issue - If so a new mouse is probably needed (assuming you cleaned the trackball/laser - video instructions can be found below)
If the mouse is not the issue, then enter mouse settings on Windows XP, and try adjusting the sensitivity etc. This can be done by going to Start -> Control Panel -> Mouse and adjusting "Pointer Options"
If this fails, try downloading drivers for the mouse (assuming it is optical).
Mar 02, 2011 | Computers & Internet
MY MOUSE KEEPS LEAVING THE SCREEN, AND GONE FOR 10 SECS..ITS A DELL LATTITUDE 600 NOTEBOOK-FIREFOX, XP
5
Feb 08, 2011 | Dell Lattitude D600 Notebook
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."
Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.
Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.
Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
Shortage?
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
Mar 25, 2009 | Gateway Computers & Internet
Magnifier doesn't work
Try going to Control Panel and click on the mouse icon. Then the mouse properties will appear showing the mouse. In the left column,move your cursor over the right side button click on the drop down and select magnify. Hopefully it will now work.
I had to move the magnify function to the left button because it was to sensitive on the right.
Nov 27, 2008 | Microsoft Wireless Laser Mouse 5000
Logitech 9312160403 Mouse Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
