Question about NewCon Optik Optics
We have the newcon optik. Wer took the batteries out to store it. We want to use itnow,put batteries in and it dont work. The number on it is (n99703638)
    Master:
  • 577 Answers
Hello there, alway check the battery. It can be check with a DMM for voltage but the battery needs to have a load on it. Hook up a couple flashlight bulbs across the + and - terminals. Then check the voltage across the battery with the load (bulbs). If the voltage across the battery is about 2.6v on a 3 volt battery with the load it's OK. Example: The same with your car battery that has a 12 volt system.---put a DMM across the terminals and it show approx 12 volts. Try starting the vehicle and if the voltage dropes below 10 volt while trying to start the auto, then the battery is or needs to charge. or it's bad Example, to check you vehicle to see on DMM if it is really charging. Start the vehicle and let it run, then check the voltage across the 12 volt battery. It should be 13.8 volts. This will indicate that the charging system of the vehicle is work. stewbison
Posted on Aug 04, 2011
Looking for a free download of the newcon lrm 1500 spd owner's manual.
Most of the time the company web site will have full instruction manuals in pdf form. You can get a free download of adobe reader if you haven't got it installed on your computer yet. You can save the file in a folder for later use and can also print it. Unfortunately it is like a photo and you cannot make changes like putting the serial number and other information on the pages. But you can always put that on notepad and put it in the folder as well. Depending, some manufacturers web sites are tricky. You have to search for it. Others have a search option and all needs to be done is put the make, model and product (newcon lrm 1500 spd owner's manual.) and it should take you to a download page.
Aug 06, 2012 | NewCon Optik LRB1500 SPD Binocular
We have BN 5 Night Vision, but it's not in working condition means after putting batteries too it does not work. please let me know hw the problm can solve.
Hello, make sure that the batteries are installed in the correct order. Also, check the battery contacts in the battery compartment and make sure that they are really clean. GB...stewbison
Sep 06, 2011 | NewCon Optik BN-5 Binocular
I have a newcon-optik stargate that will only come on about 1 second after I press the lever. It only worked about a week after I bought it although I can't send it for repair under warranty right away...
Hello, it could a bad switch. Have you tryed hold down on the switch and see that works. If so, then the switch is faulty. You know that this NewCon Optik CON STARGATE-M is Russian manufactured by Optik one of the six or seven Russian companies manufacturing these NV devises. GB...stewbison
Aug 31, 2011 | NewCon Optik CON STARGATE-M
Where to access the battery compartment to replace batteries on Tasco NV 356
It could be on the top with a small hatch door that holds two AA batteries. Also, there could be a screw in cap on the back that could hold one or two CR123A 3 volt batties.
Unless it has finger crip lever on the top, this piezo electric plunger. The plunger needs to be activated about twenty plus times to build some current for the storage capacitors that will charge a small batteries. stewbison
Jul 10, 2011 | NewCon Optik con Tasco NV-356 1st...
Was wondering if there was anyway to take the lens off my Newcon BN356/BN456 Binoculars to clean them?
Yes, First, when you take the lens off you binocular make sure you are in a very clean room.
All you have to do is unscrew them. Use a good lens clean that is anti-static. If you don't every piece of lent, dusty bugs, flaky shin, etc. will be attached to those lens. stewbison
Mar 31, 2011 | NewCon Optik BN-5 Binocular
Little black and white dots inside the lens
It's not a problem with your NV monocular. These spots will occur on any image intensifier tube. EXAMPLE: Military standard states that if more than one black spot appears on the tube, then this image tube is rejected for use by the US Military Now like you NewCon Optik DN 140M it manufactured in Russia and they quality control doesn't even match the US Military Standards. On scale 1 to 10; US Military rating for the image tube would be 10+ while the Russian maybe 2+ and I said maybe. Another thing to remember here is that no two image intensifier tubes are the same. It just like finger prints on people not two are the same. It normally. stewbison
Dec 05, 2010 | NewCon Optik DN 140 M
No image at all
Try replacing the batteries with brand name, photo quality AA's (energizer E2 lithium would be my first choice). 1st gen night vision devices (which is what the NS-156 is) are very sensitive to voltage, and cheap batteries just don't have the "oomph" to power up the intensifier tube. I've bought quite a few "broken" 1st gen devices for between $20-$50, "fixed" them with good batteries, sold them and usually at least quadruple my $$ off the deal. No guarantee, but it's a great place to start. Good luck!
May 14, 2010 | NewCon Optik NS 156 Weapon Sight
Newcon Optik Night Vision Binoculars BN5
The lenses screw out, the electronics are in the body and this involves removing all the screws, including the ones behing the rubber casing. Why do you wish to strip them out?
Nov 06, 2008 | NewCon Optik BN-5 Binocular
Night vision
go to google then click on shopping it is the best way to get items hope this helps.
Feb 21, 2008 | NewCon Optik NZT 22 Goggles
Newcon BN5 bipppppppppp
Try contacting these guys, i cant find any online info about this fault, it sounds like a serious problem in the circuitry that can be fixed - the biiiippp is an error message and the shutdown should protect from further damage; http://www.newcon-optik.com/contact_us.html Hope this helps :)
Mar 31, 2007 | NewCon Optik BN 5 (2.5x62) Binocular
Optics Logo
176 people viewed this question
Top NewCon Optik Optics Experts
james laughton
james laughton
ray gallant
Are you a NewCon Optik Optic Expert? Answer questions, earn points and help others
