My go gear went tho the wash it switchs on and when i plug it in to my laptop it finds wot files igot on there but i got water behind the screen any surgestions?
  • 36 Answers
I guess the only thing you can do is to buy a new one.
Posted on Mar 22, 2011
My Kindle went blank with almost a white screen tho fully charged and now wont turn on at all. Have followed Amazon's suggestions but nothing works. Can you help?
Chances are your screen went defunct. Or it could be a problem with some other piece of hardware. You can try using the USB cord to plug it into the USB port on a laptop or desktop and see if the computer can read the files. If it can display and explore folders and files, chances are it's the screen (display) that went south. It it can't display and read folders and files chances are it's the memory or some other internal hardware that died. Sadly these things are cheaper to replace than to repair. I have a Kindle II with a faded out display. It works but the text is so light that it's barely readable so I retired it. I have a Kindle Touch that I dropped and the screen broke so I ended up getting a Kindle Paper White and I like it the best of them all.
Apr 22, 2015 | Amazon Kindle 1
Why will it not fill with water but will drain water?
The problem could be 1 of several.
1. Ensure the fill hoses are attached correctly ( hot and cold hooked to correct fill valve positions) and turned on.
2. Are you sure it's not actually filling with water but you're not seeing it because the water level is so low. If it drains the water has to be coming from somewhere!
3. There are screens inside the fill hoses attached to the fill valve behind the washer that can be plugged. When city workers flush lines sand can be forced into the home supply lines to plug these screens.
4. Bad pressure switch or the switch can have suds residue to cause intermittent problems.
Sep 01, 2014 | Kenmore Washing Machines
I replaced passengerside regulator, wheni plugged it, it immediately went up. but no i wot do anthing
either your driver window switch or the passenger window switch is making a constant connection causing window to rise i would strongly recommend leaving the new regulator disconnected until you find the fault for prevention of motor damage.
Aug 16, 2013 | Cars & Trucks
Igot a blank screen when i start my sl410, i didn't find anythink.
Possible inverter if the screen doesn't work, but an external monitor does.
Feb 04, 2011 | IBM Lenovo ThinkPad SL410 Notebook
Ken more wot stop filling but think i got it want to make sure
A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Mar 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
The machine suddenly "clicked' when I took laundry out and seems "dead"- Is it switch possibly pannel switch that stop working? When I rrotate knob and pull it out- no response- no electricity and no...
The control board went bad. Your switch went bad or you blew the fuse. All are located behind the knobs. Just remove the knobs and undue the screws up top. Make sure to unplug the system before opening it up
Jan 02, 2010 | Maytag PAV2300 Top Load Washer
Lights on but wont start- can I reset it model GW608 fisher &paykel
  • Hi,
  • try these:
  1. Check that the washer is plugged in securely
  2. Check the circuit breaker or fuse box
  3. Test the outlet for current
  4. Check that the water supply valves are turned on
  5. Inspect the filter screens
  6. Test for overheating
  7. Test the water level switch
  8. Test the timer control
  9. Test the lid switch
  10. Test the water inlet valve
  11. Inspect the water pump
  12. Test the centrifugal switch
  13. Test the motor
please rate my suggestion....
May 22, 2009 | Fisher Washing Machines
My toshiba satellite l300 laptop wont connect to my wireless device this is wot its saying is wrong wot does this mean and how do i fix it atheros ar5007eg pci/ven_168c&dev_001c&su code 43 thats wot it is...
The Atheros AR5007EG is a wireless adapter card, that plugs into your Toshiba Satellite Pro L300 laptop. The Code 43 means Windows doesn't recognize it anymore. I suggest it's either a Driver problem, or the wireless adapter card itself is bad.
This is Toshiba Support. On this page you will see the following headings,
1.Choose Category
Click on Laptops
2.Choose Family
Click on Satellite Pro
3.Choose Model
Using the side bar, click on the down arrow, and scroll the models down. You need to click on the exact model, of L300 you have.
As you can see, there are many. Look on the bottom of your laptop, and you will find the exact model number. I suggest you write it down. Then match it up to one of those model numbers.
When you have matched it up, click on it. Then go to the right, and click on GO, in Red.
Since I do not know your exact model number, I'm going to choose -> L300-EZ1004V <- (First L300 in the list), for an example,
(You Must have the exact model number. You need THE drivers for YOUR laptop)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2041070&rpn=PSLB1U&modelFilter=L300-EZ1004V&selCategory=3&selFamily=1073768667
This takes me to the main page for support, for the Toshiba Satellite Pro L300-EZ1004V
You will see the Support Bullitens for this laptop, and the Support Bulliten tab.
Click on the -> Downloads tab.
The above page is what I get. I'm on Page 3. If this link doesn't take you to Page 3, then go to the bottom, and click on 3, or click on ->
Next, until you are on Page 3.
On Page 3 you will see ->
Atheros Wireless LAN Driver for Windows XP (v7.4.2.75;04/07/2008;5M)
For the Atheros Wireless LAN driver, for THIS laptop, that's what I would click on. Then I would click on Save. If you don't have your downloads saved to your My Documents folder, it will go straight to your desktop screen. This is for whatever computer you are using to download this driver file.
You then burn this file to a CD disk. This disk is installed into your Satellite Pro L300 laptop. When you save it, try to save it to your My Documents folder. Then go to Start>My Documents, and double-click on this file. It may be a zip file. If so, the Extraction Wizard will come up, and you go to the top left, and click on ->
Extract All Files.
Then click on Ok, and in the next window click on -> Next.
Look for a file that states -> Setup, or a file that ends in -> .exe
Double-click on that file. If you get a Microsoft warning window, ignore it. Click on Run, and Run again.
NOW remember! The above IS JUST AN EXAMPLE!
You need to find YOUR exact model number, and go through the example shown above.
Apr 24, 2009 | Sony Computers & Internet
Blub
Sounds like the lcd screen has gone out . Hopefully you still havea warranty on it. But a good way to test if its the lcd screen or the graphics card is to hook it up to a external monitor and see if the pitcure comes up if it does then its the lcd if it doesnt then its the graphics or motherboard itself
Feb 13, 2009 | Acer Aspire 5315 Notebook
18 people viewed this question
 Grubhead
Grubhead
