Question about Kenmore Dryers
I have a kenmore dyer model 41783042201 the timer does not move and the dryer keeps running
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
If you have heat, the timer will need to be replaced.
Kelly
Posted on Mar 22, 2011
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
How to fix heating problem with kenmore dryer model 41783042201
Disconnect power from the unit
Remove the top
drop the panel between units
remove the control panel
remove the front
access the rear hatch and release the idler
Remove the drum
Now you can inspect and repair the heater pan
MY PAGE WITH VIDEOS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 07, 2012 | Kenmore Dryers
I have a kenmore dyer model #10070602990, the dryer spins, but it does not heat up. what could be the cause?
thermal fuse, heating element, timer, or thermostat:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Here is another website that is helpful:
http://www.applianceaid.com/general.html#timers
Feb 16, 2011 | Kenmore Dryers
I have an older model...........maybe 8-10 yrs and i turned it on lastnight and this morning it was still running. the knob that is like the timer didnt even move???? i opened it up and the clothes were...
The gas turned off when the temperature is detectd by a thermal sensor. The timer is not working therefore the motor keeps running until you turned it off. The timer need to be replaced.
Apr 27, 2010 | Kenmore 72602 Gas Dryer
Dryer timer not working on a kenmore dryer model 80 serious
HI, if this device isn't working, you will need to replace it. it cannot be repaired. it is designed to fail and when it fails, you will have to replace the entire timer control module.
This device control all aspects of the cycle you initiate.
May 23, 2009 | Kenmore Dryers
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
A common problem, had it happen to me.
Replace the timer control. takes about 15 minutes and the skill to remove screws, disconnect plug from old timer, remove timer, install new timer, connect plug, replace screws and panel, run dryer.
Reply the model number, and I'll get you the timer P/N.
Jan 15, 2009 | Kenmore 97572 Dryer
Dryer quit heating up,timer doesn't work,this happened all at one tim
no dyer run's just does not heat up,timer never move's,which I think need's too for dyer too heat up,i could be wrong,just happened all at one time
Aug 03, 2008 | Dryers
Kenmore dyer
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
Jun 09, 2008 | Kenmore 62802 Electric Dryer
Dryers Logo
82 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
