Question about Optimus Audio Players & Recorders
Optimus 900 MHZ wireless speaker transmitter & 18 VDC adapter for transmitter. My wireless speakers quit working & I think the adapter for the transmitter is dead, and it might have also destroyed the transmitter. I need replacements for these. I have part numbers from a RadioShack list, but they don't have them anymore. Help ?
2 Suggested Answers
SOURCE: I have a Prolink wireless
I have Prolink 900 MHz wireless loudspeakers, probably the same as yours. The transmitter is labelled on the bottom as "CAN 2579 102 1811, UNI-ART PRECISE PRODUCTS LTD". That transmitter comes with an AC/DC adapter whose output is labelled as 12VDC, 300mA, with polarity positive outside, negative inside. Note this polarity is the OPPOSITE of what is typical for AC adapters.
Posted on Dec 06, 2010
My husband three away my transmitter to my Centrios 900 MHZ DIGITAL HYBRID WIRELESS OUTDOOR SPEAKERS. #4015004
So many of these things are made generic and have limited production run. The OEM is not traceable. I
would recommend getting the whole set.
Jun 05, 2017 | Centrios Audio Players & Recorders
Replacement power supply - can i convert AC to DC output connector?
I'm not clear on the four pins of the DC power supply for the speakers. Do you think there two different voltages needed??? It's not worth trying to convert your ac power supply/ It would take a few parts and you will not end up with 18 vdc. You can purchase a 18 v dc adapter for as little as 15.00.
Jun 16, 2014 | Altec Lansing M604 Computer Speakers
How many volts is the power adapter
The speakers use a 10 Watt power supply
Sep 06, 2011 | Sony SRS-A37 Computer Speakers
I have a Prolink wireless 900 Mgh wireless speaker system. I have just moved and have lost the plug in adapter for the transmitter. could you tell me what the adapter voltage is into the transmitter. ...
Sep 14, 2010 | Audio Players & Recorders
I have a 900 MHz Wireless Indoor/Outdoor Mono(Accurian)
yep the power to it is in question and since it is a 9 volt adaptor as mentioned that will need to be checked 9vdc adaptors are over the counter items in most radio shops
Jul 29, 2009 | Audio Players & Recorders
Instructions on how to hook up outdoor speakers to computer
Get a set of wireless speakers (such as Advent AW-820 900 MHz Wireless Stereo Speaker System).  Connect the transmitter to the earphone jack of your computer.
May 20, 2009 | KLH Audio Players & Recorders
Can Acoustic Research wirless speakers be used for surround?
yeah, I looked it up on thier website. Here is what they say.
Warning: This product is designed to work with line level outputs or headphone outputs only.
DO NOT connect it directly to speaker outputs as it will permanently damage the transmitter.
You can use these as surround speakers if you like. You just need a line level surround output on the receiver. Most high end receivers have this feature but, you may only have speaker level outputs.
If that is your case the only option you have is to use a "speaker to line level adapter".... http://www.crutchfield.com/p_543ADP12/Russound-ADP-1-2-Speaker-level-to-Line-level-Adapter.html?tp=9070
Now crutchfield.com is always a little high on prices but if you look around I have seen them around $10 online.
Good luck with your project.
Jan 28, 2009 | Acoustic Research 900MHz Wireless Stereo...
Cylinder Like Sharper Image Indoor/Outdoor Wireless Speakers
ask google or you tube or go to car toys they can help. good luck
May 18, 2017 | Sharper Image SR277 Speaker
No sound from rear speakers on the lifestyle 18
The SL2 works in such a way that the speaker satellite out put from the bass modules is fed to the input of the SL2 transmitter (remember, transmitter) then the sattellitespeakers are connected at the other end of the room to the receiver. An initial blinking green light should be seen and once the system is turned on this turns into steady green. Both the SL2 transmitter and receiver operates via WIFI.
Glad to be of service...
Dec 21, 2008 | Bose Lifestyle 18 System
Spkrs quit receiving signals
Hi, assuming you can open the enclosure of the Advent, work on the amp section (please make sure you've isolated the power supply and you will be working with the low voltage section of the circuitry only.) Inject an audio signal, it does not matter where in the amp section, just try the different solder points of the small capacitors normally in the 1uf value. at least one of them should give you a good amplified output from the speakers. In the absence of a signal gen, you may want to try (with care)using your bare finger which should produce a humming sound of about 60HZ or a slight thump in the speaker. If such a sound is produced, then the amp is good and the powersupply is doing its work. You have now isolated the problem to the 900MHz receiver. Am not sure if you can purchase modular replacement in your area but you can also try the sig gen or finger method except for the front end (rf section). Re the humming sound, such a problem is normally related with the power supply section with a defective or leaky capacitor. It is also possible that the input stage of your amp is not grounded right. You actually have just to work on it in stages to simplify fault diagnosis. Since you can hard wire, why not try salvaging parts/module from one unit and putting it in the other to make at least one working while looking for replacement parts/module for the other half of the Advent. Hopes this work out for you. Please let me know how things turn up. Regards
Apr 09, 2007 | Recoton Advent Advent AW820 Computer...
884 people viewed this question
Top Optimus Audio Players & Recorders Experts
Larry Stiles
Larry Stiles
Craig Butler
Craig Butler
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
