Question about Sylvania G-Netbook
Will not log into local network - Sylvania G-Netbook
We need to invest in a real notebook , laptop,this one just doesn"t work with internet< nobody knows what windows ce is. go get your money back
Posted on Mar 22, 2011
Windows unable to find a certificate to log on to the network
Sometimes domains are not available until they are removed and re-added to a machine. You can try logging in locally as an admin, remove it from the domain, verify you are on the network, reboot, and add it back to the domain. A local machine login circumvents the need for a cert to login, but does not give access to domain resources. This will allow you to work on the machine and test the NIC you are troubleshooting.
Dec 02, 2013 | NetGear WG111 802.11g/b Wireless Adapter
Tip
Allowing Network Access with Blank Passwords with Vista
Although you can log in locally without a password, by default, Vista does not allow network users to access the computer without a password.
To change this setting:
Run gpedit.msc
Go to Computer Configuration / Windows Settings / Security Settings / Local Policies / Security Options
Double click on Accounts: Limit local account use of blank passwords to console login only
Disable this option
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Unable to log in and can't change Domain?
Log on with local admin account. When you can't do it, you have to reconncet it to the domain and take it out of the domain otherwise new installation.
Jul 27, 2012 | Dell OPTIPLEX 745 PC Desktop
I want to connect to internet using this unit please help me
  • Figure 1
    The strongest local wireless network connection
    is displayed on the N95's Active standby screen. In this case the phone has found a network called 'mat'
  • Figure 2
    To search for more WLAN connections, click Options, highlight Search for WLAN and click Select
  • Figure 3
    To connect to a WLAN network, highlight its name and click Connect
  • Figure 4
    If the wireless network is security-protected, you'll need to enter its hexadecimal WEP key to log on
  • Figure 5
    You can also connect to a WLAN using the WLAN wizard. This can be found in the Tools are of the Main menu
  • Figure 6
    When opened, the WLAN wizard displays a list of the available local wireless networks. Highlight one and click Options to log on
Feb 28, 2011 | Nokia N95 Cellular Phone
Dear Vendor, I have a problem related to connecting to the login to the 3COM Switch 4500 26-ports. I am currently using computer Laptop model Acer Spire 4935, and my computer has no serial port. So,...
You can log into a Switch 4500G Ethernet switch in one of the following ways: ? Log in locally through the Console port ? Telnet locally or remotely to an Ethernet port ? Telnet to the Console port using a modem ? Log into the Web-based network management system ? Log in through NMS (network management station)
Dec 29, 2017 | 3Com Switch 4500 PWR 26-Port...
Network issue
Hello
This is an unusual error. Error Code 1236 - The network connection was aborted by the local system.
There is no single issue that causes this error code, so we need to verify all of the networking basics are covered and working.
1. Verify the IP address, Subnet Mask and Default Gateway are fully entered and / or populated by the DHCP server. Click START, then RUN, type in CMD then click the OK button. Type IPCONFIG /ALL - verify the three fields all have valid info for your network.
2. Verify you can see the local network - including other computers and network devices. This will rule out the possibliity that this computer cannot see any network devices and not just the shared folders
3. Log the user out and have another user that can access the shared folders log into this comptuer and try to access the shares. The user profile could be corrupted and preventing the user from accessing the shared folders. IF the new user cannot access the shared folders, then it is the PC / OS causing the issue. IF they can access the shared folders, backup the original user's data, delete their profile and have them log in again to create a new profile.
It is always recommended to upgrade Windows XP to Service Pack 3 - unless you have a very specific program that will not run on SP3.
May 04, 2010 | Microsoft Windows XP Professional SP2
Unable to log in on network. Error message ''The domain can not be found'' what is the cause of this. Have logged in as Local Administrator to find IP address 169.254.0.21. How do I fix this
If this problem just started on a network that was working try resetting (unpluging) the router and modem. Another option is to do a "repair"
I assume this is a wireless connection.
Open your wireless network connection and go to the support tab.
Here is where you can do a repair. This will reset your network adaptor.
Try this and it should solve the problem.
Nov 08, 2009 | Computers & Internet
Windows cannot locate the server copy of your roaming profile and is attempting to log you on with your local profile. Changes to the profile will not be copied to the server when you logoff. Possible...
When you "logon" to your local network, your computer is configured to fetch your "desktop" (My Documents and wallpaper and everything else) from a "server" computer on your network.
Was your "logon" to the local "domain-server" a successful login?
Does your local Network Administrator indicate that the "domain-server" is functioning properly?
Does that server's log-file show any error-messages, such as "not allowed to login between 10 PM and 6 AM" (a "security" setting on the server).
Since your "desktop" could not be loaded from the domain-server,
your computer has used a "local" copy of your "desktop",
and it is warning you that any changes will *NOT* be "merged" back to your "network" profile.
Have you contacted you local Network Administrator? What did she say?
May 25, 2009 | D-Link Computers & Internet
Problem in proxy settings
Log Out...Could not Connect...
Dear User, If you are behind a firewall or within a company local area network (LAN), you will need to open outgoing TCP connections to Port 51215 on your proxy server.
Oct 27, 2008 | Computers & Internet
Unable to log on to network with Apple Laptop
The type of computer doesn't matter, as the protocols are the same. Check your router's dhcp settings, as you may have it set to allow too few IPs to be distributed.
Apr 09, 2008 | Linksys RangePlus WRT100 Wireless Router
Sylvania G-Netbook Logo
32 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
