Question about Kolcraft Tender Vibes 18189-TX Crib
Can put back together after washing the fabric ?
  • 396 Answers
It's easy. Hold the main skirt fabric and drop the pressboard support into the bottom with the feet/nubs down away from the inside. Now the metal frame drops in and next slide the hinged U supports outward. This raises the edges and gives height to the bassinet. The U supports either lock under a plastic clasp on the pressboard or sit into holes on the board. Now button down all the buttons around the interior or zip the zipper closed. Set it back on the frame and snap the bassinet to frame snaps on. Add the hood and baby's new, clean bed is ready for a lullaby. Good luck and you should be able to download a PDF version of the instructions from the maker. Just go to their site and search.
Posted on Mar 23, 2011
I have a fisher&paykel washing machine every time l wash my clothes it leaves Dirty marks on my clothes I have pulled out the barrel and cleaned it and put it back together and it still leaves marks
With no clothes in the machine, Do a long hot wash, add some bleach, stop using fabric softener. Cut down on soap usage. This should clean out the machine. If it happens again, there may be a mechanical problem which is allowing grease or oil into the machine.
Mar 20, 2017 | Fisher and Paykel Washing Machines
Have you got a image of how to put maxi cosi back toteaer onced washed
Good Afternoon
When the fabric is removed for washing it should not be overly complicated to replace the fabric after washing. The only instructions for removing the fabric can be followed in reverse order to put the fabric back on can be viewed on the Facebook page under Dorel UK Customer Services.
If the harness has been pulled out of the seat it will need to be replaced by the engineers due to the safety implications of it being put back incorrectly. To organise this please contact the customer service team on 01284 413 141 Mon-Fri 8.30-4.30.
Sep 19, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How do I get apart. The agitator is broken
The fabric softener comes off, pull straight up. Then the upper agitator unbolts from the top. Be careful to properly align when you put it all back together.
Jan 09, 2011 | GE WBSE3120B Top Load Washer
Reattach seat to Evenflo Exersaucer
Match the red arrow on the fabric seat to the middle of the seat back. Use a crochet hook to fish the elastic straps through the slots. Pull the elastic straps to hook on to the tabs on the lower rotator fastener. The key is to pop the fabric seat up into a cone, so that you can see what you're doing.
Feb 07, 2010 | Evenflo Baby Gear
How do I dissemble a Graco Pack n Play Mini Sport playpen for cleaning???
It is not designed to be disassembled for cleaning but I have done it. Just be very methodical and keep track of how things come apart. Label them with tape to make it easier to remember. Wherever there are screws holding a joint together take them out one joint at a time. Start at the bottom. When you get to the rails at the top remove the screws and pull the rails out of the "sleeves" The vertical rods at the corners will probably come out last. Wash the fabric and then put it back together in reverse of the way it came apart. you may have to release the locks on the rails to keep the fabric loose enough to get them out after taking out the screws. You may have to remove a few screws in the center locking device to loosen the collar that the fabric fits into. Watch how the parts are arranged so you can fit them back together. I think once the collar is loosened the fabric can be slipped out without having to completely separate the parts. (Having an engineering degree was helpful.) Good luck.
Jul 08, 2009 | Graco Pack 'n Play
Fabric softner still in draw when wash finished
There is a blockage in the dispenser that is causing the prob.
Remove drawer from dispenser, and thoroughly clean every part of it, taking all the pieces out to do it.
To test it is working, put it back together, and before you put it back in, fill the conditioner compartment with water until it starts to overflow, turn water off, and the remaining water should continue to run out, until it is empty, if it does not , then it is still blocked.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Washing Machines
Instructions on putting stroller fabric back on stroller..
you can download the manual here: http://www.safety1st.com/instructions/.
Basically, the easiest way is to put the back in, then start at the bottom and work your way up.
Aug 04, 2008 | Safety 1st Acella LX Winnie the Pooh...
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Kolcraft Tender Vibes 18189-TX Crib Logo
584 people viewed this question
Top Kolcraft Baby Gear Experts
Timothy Shotwell
Timothy Shotwell
Level 1 Expert
Jennifer Rock
Jennifer Rock
Bill Boyd
Are you a Kolcraft Baby Gear Expert? Answer questions, earn points and help others
