Question about Clarion DXZ545MP CD Player
When changing radio channels the dx mode appears instead of lo (local) cant get a signal
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Clarion Master
  • 2,226 Answers
Dx is short for distant. this just makes the tuner more sensitive and should pick up more stations. if it is not picking up stations in dx mode, you either have a bad antenna or a bad tuner.
Posted on Mar 22, 2011
My galaxy radio is stuck in split mode how do i get it out of split mode
perhaps the taktile switch that chooses has gone and needs changed
so its off with the controls and front panel and replace the switch
Dec 07, 2014 | Galaxy Radios DX-2547 40-Channels Base CB...
I bought a 2002 citroen c3. the clarion cd player works fine but when i put it on radio theres no signal just silence. I press scan and it briefly says LO then goes to DX and just keeps scanning. ive...
Remove radio from car dashboard, disconnect antenna and put about 2-3 m wire into it instead. Try to search for any radio signal - if it's finding something then aerial amp is broken. As far as I remember it's in aerial base and might need replacement.
May 16, 2014 | Car Audio & Video
Where should I have my rf gain selector hi or lo
rf gain is about local coms if you want your cb to RX far away stuff set it too high but local stuff like friends family that are local then you want too set rf gain to low then only local signal can trigger the squelch ... so the radio will ignore the static and only trigger you when needed ? see what i mean rf gain ye a DX guy will set it high or too listen to people like over 50K away
and let then break the squelch...min
Mar 24, 2014 | Connex 3300 240-Channels Base CB Radio
Galaxy 2547 off frequency
1 one thousandth of a number and you are worried. now if it said 27.18350 instead of 27.1850 then you would be off frequency.but for that little bit its not even a problem
Mar 06, 2013 | Galaxy Radios DX-2547 40-Channels Base CB...
Cant get my 99v to chang channels
Please be more specific. It could be the channel selector to the channel board in your radio, to a slew of different things.
Feb 06, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
I have a cobra 200. The receive is some distortied, Most signals appears to be overmodilating with normal volume.
When the signals you are receiving are too strong "over-modulated" turn back your RF which will turn down the sensitivity of your receiver. If they are still over-modulated it may well be the other person has their modulation turned up too high from changing the setting inside their radio, turning up their mic gain or having their power mic turned up too high.
Jan 27, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
Haven't used my dx-88hl cb for years. what d9 i set the band on?
I'm not going to be corrected on this as i'm tempted to say A or C and sometime D. Instead i would say switch channel to 19 then watch frequency counter as you change band selector until you find 27.185 and you have arrived.
Dec 27, 2010 | Galaxy Radios DX- 88HL Base CB Radio
How do i change my vhs from US to INT AS I CANT FIND MANUAL. IT THE SOLAR MODEL?
From page 4 of your owner's manual:
WX/ALERT/UIC - Press this key to listen to active NOAAWeather channels.
Press and hold this key for 2 seconds to place the radio into the Weather
Alert mode. Press both HI/LO/SCAN/UIC and WX/ALERT/UIC at the same
time to change channel modes from USA to INTERNATIONAL to
CANADIAN.
Aug 14, 2010 | Uniden Solara Vhf Dsc Fixed Mount Radio
Radio clicks on and off during transmit.
Hi Dispatcher,
There might be a few things going on here. You say you hear clicking, regulator woudnt be doing that as they are solid state. It could be a relay, some radios have relays instead of electronic switching when you key up.If the voltage is too low that can cause the relays to "chatter", I would look into that first. Can you take the radio to your vehicle and hook it up there ? ( If you are set up for that) just to see if your battery will drive it better.
Are you running a Kicker or modulator? Lets get this sorted out and see what happens,there are other things but lets try one at a time.
Good Luck,
Tom
Dec 30, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Manually change radio stations?
Here is how to manually tune your radio.
1 Press the SOURCE button until a radio
frequency appears in the display.
2 Press the BAND button repeatedly until the
desired radio band is displayed.
Each press changes the band:
→ F1(FM1) → F2(FM2) → AM
3 Press the TUNE button repeatedly until "DX
SEEK" and "SEEK" disappear from the display.
NOTE
The initial mode is DX SEEK.
4 Press the g DN or f UP button to move
downward or upward one step respectively until
the desired station frequency is displayed.
NOTE
The ST indicator or STEREO indicator appears on the
display when a Stereo FM station is tuned in
You can also look at your manual here for any other ? you might have
http://akamaipix.crutchfield.com/Manuals/500/500CDM7874.PDF
Dec 17, 2008 | Alpine CDE-7858 CD Player
Clarion DXZ545MP CD Player Logo
161 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
