Question about Samsung NC10-14GW Notebook
Battery not charging samsung nc10- was OK the other day now just intermittent blue flash when plugged in. unplug and no power. removed battery and charger works. Fn F2 00% battery life!!- do you think a new battery will sort this?
    Master:
  • 362 Answers
Try holding the power button for 30 secs with the battery out and unit powered off it allows a static discharge and might help its what my wifes g60 requires from time to time good luck and hope this helps you out some
Posted on Mar 22, 2011
    Problem Solver:
  • 7 Answers
Run it on battery power only.
Let the program run for a while and see if the pink "Power" number is changing.
If it is,you are drawing power from your battery,
if it isnt changing,well,there is something wrong with your battery I would imagine.
Also click on "Batteries" up on top and see if Status says "Discharging"
if the battery also can not work,you should buy another one,suggest you buy form the list shop:
http://www.batterywood.com/laptop-battery/samsung-nc10.htm
Posted on Nov 13, 2012
Flashing orange power light
laptop works ok? battery is charging? you have no problem???? do nothing?????
Oct 27, 2013 | Dell Inspiron 1545 Notebook
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My NC10 has a crack in the in screen and has destroyed more then half the screen... Can this be fixd? Or is itcheaper to get a new lap top??
My viewpoint is that it's worth repairing,.....that is if YOU do it.
A couple of places from a quick search, that carry the LCD screen for Samsung NC10 series laptops,
http://www.laptopscreenonline.com/samsung-nc10-replacement-screen-laptop-lcd-5863-p.asp
http://www.amazon.com/SAMSUNG-NP-NC10-LAPTOP-SUBSTITUTE-REPLACEMENT/dp/B003TP6K1G
This site has the Service Manual for the Samsung NC10 series of laptops, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-samsung
Click on the blue NC10.
[This is a PDF file. The computer you are on now has Adobe Reader on it, which uses PDF files.
Allow up to 30 seconds for the file to download)
Replacing the LCD screen is a fairly straightforward affair.
Remove ALL power to the netbook. Remove the AC adapter (Charger) and Battery.
Follow the Service Manual.
If you have additional questions please post in a Comment.
Regards,
joecoolvette
Jun 06, 2011 | Samsung Computers & Internet
NC10 battery not charging. The charging light flashes as normal but battery wont charge, tried another battery with same result.
Allow 1hour to charge it, if did not charge check the input & output of the charger if its properly insert, if not again off your notebook & charge it, always check if it is charging,
Note: Charging test try on, off, & unuse it allow to full charge the battery before using..avoid low bat your battery when using.
Jun 03, 2011 | Samsung NC10-14GW Notebook
My nc10 is not charging, but works when plugged in
This usually indicates a problem with the laptop's battery.
How old is your battery? More than three years?
Did you notice a considerable decline in unplugged time(the time you work on battery without being connected to mains supply) before it stopped working?
If the battery is too old or if you noticed a severe decline in unplugged time, get a battery.
If anything else, it needs to be check by a professional.
Mar 03, 2011 | Samsung NC10-14GW Notebook
My NC10 won't turn on, no life at all. Battery light charge light shows green. any idea's?
Try a atx-reset.
No battery, no adapter and push the powerbutton for 1 minute.
Put in the adapter and try again.
Feb 17, 2011 | Samsung NC10-14G Notebook
Hello, i have a samsung netbook that is not working. the blue "on" light comes on, but the screen is totally black. can you help?
DEAR
Try this
  • Unplug the power,
  • Remove the battery and then hold the power button for 30 to 60 seconds.
  • Then reattach the power and attempt a boot.
  • Just shutdown, put the battery back in you're good to go.
Worked so definitely worth a try.
------- YOUR CHIRAG ----
Jul 17, 2010 | Samsung NC10-14GW Notebook
Samsung NC10 will not boot up
Take it back to the store and get the manufacturers to fix it.
Jun 13, 2009 | Samsung NC10-14GW Notebook
Samsung NC10-14GW Notebook Logo
2,139 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
