Question about Hatco C 24 Compact Electric Booster Water Heater
What is the resistance on a element on hatco c 15 booster heater when its good
  • 37 Answers
I have some one getting back with me on particular numbers but it has been my experience they are either good or bad.If you show continuity then it is probably good.when checking continuity make sure you unhook both wires from element.then check from one side of element to the tank for continuity you should not get anything the meter will read ol.if you do get a reading then the element is bad replace it.
Posted on Apr 22, 2011
  • h8bnpo Apr 25, 2011
    208 v,5000w,8.6 ohms
    208 v,6000w,7.2 ohms
    208 v,7500w,5.8 ohms
Hatco booster blowing breakers
Copy following link:
http://waterheatertimer.org/Water-heater-is-blowing-breaker.html
Hatco booster heater typically has 2 sets of thermostats and elements located on each end of heater.
Both sides might be controlled by same 60 amp breaker, or the heater might be controlled by two separate 30 amp breakers.
Be sure you have correct wire and breaker.
After reading steps on link above, add comment and say if this is new installation, or older installation that suddenly started throwing breaker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 08, 2013 | Hatco 208/3 C-12 Compact Booster Water...
Leaking drain, I think?
hatco booster heater leak at pop off valve
Dec 27, 2009 | Hatco C 24 Compact Electric Booster Water...
No heat on rinse cycle HOBART AM14C Dishwasher
3 Con, is the booster heat contactor. If it is chattering, the fault will be in the booster. There are a few different boosters in the AM14. can you post the ML number from the data plate, or describe if the booster is a square Hatco HCM-10, or a round stainless booster with a 13 kw multi wired element.. All boosters use a low water cut off circuit, a high limit thermostat and a control thermostat. The old Hatcobooster uses mechanicqal components, where the new rount tank uses probes and a control board. The board has 3 leds. red is calling for heat, yellow is open thermistor, and green is shorted thermistor.
AM14's had a variety of different control circuit voltages, ranging from 240/208/120 and 24 volt AC. Check the transformer secondary for correct output to controls, trace through circuit until voltage pulses. If new style, it could be just scaled up probes not reading water. Drain the tank with the power off before removing probes.
Jul 03, 2009 | Hobart AM14C-155 Dishwasher
We need a new thermostat for a Hatco booster heater dishwasher
Try Rick at Restaurant Parts and More in Ohio. Have model and serial number. He's pretty good at getting stuff like that and he reasonable on prices. I'm in Ga. and I have a 3 day turn around on anything I order from him. He's a straight shooter too. If he can't help you he'll try to find some one who can.
Feb 26, 2009 | Hatco Corporation Compact Electric Booster...
Hatco c 12
hi my name is mark. hi limit safety has a red reset button follow link to instructions to adjust rinse temp to dishmachine. i hope you are not using this unit as a home water heater. http://www.hatcocorp.com/productinfo.nsf/AllDocumentationAttachments/14B2C666CC6F114286257107005AC28E/$File/EBOOSTERM-0406.pdf?OpenElement
Feb 09, 2009 | Hatco Corporation Compact Electric Booster...
With the hatco booster water for automatic dish machine
Under normal and regular operation Hatco recommends that the unit be turned on at all times.
If the booster heater will not be used for an extended period of time or will be exposed to freezing conditions it should be drained to prevent damage to the unit.
Jan 28, 2009 | Water Heaters
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Hobart LX 18 needs compatable booster heater
A hatco C9 or C12 would be plenty big enough.I would use the larger kw unit if incoming water is very low,but it needs to be 140 degrees coming in so it doesnt sometimes trip the hi limit.
Oct 11, 2008 | Hatco C 24 Compact Electric Booster Water...
Booster heater quits heating water after a few minutes of use and you must hit reset button to get it to work again. What would be causing this? For Hatco C36208 Booster Heater 3 phase
#1 I would check that you actually have 3 phases connected. #2 I would also check the ground. There could be a loose ground, or depending on the installation, the ground could be defeated by rubber washers in flex lines. Fix this by running a wire from the casing of the water heater to the pipe, bypassing the flex lines.
#3 Replace the thermastat. The thermastat has the reset button on it.
#'s 1 & 2 are very minimal in cost. #3 is still affordable.
Please rate this solution
Jul 23, 2008 | Hatco C 24 Compact Electric Booster Water...
I have a Whirlpool 30 gal. electric water heater. Model E1F30HD035V, product # 0826237, dual element. It is in a seasonal home. Last weekend June 28 it worked fine. This weekend July 4th, it won't heat. I...
It is not unusual for an element to fail when turned on after non-use.
Turn off the power, and check the electrical resistance of each element. If either is infinite, then it needs to be replaced. Also, if only one is bad, then it can cause the whole unit to malfunction and not heat the water.
Jul 07, 2008 | Hatco C 24 Compact Electric Booster Water...
Hatco C 24 Compact Electric Booster Water Heater Logo
216 people viewed this question
Top Hatco Kitchen Appliances - Others Experts
Craig Butler
Craig Butler
Pat
Pat
Level 1 Expert
Tom Chichester
Are you a Hatco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
