Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
Am unable to import video from Sony DSR-PD170 into my laptop. Have tried importing with Adobe Premier 9 & with Windows Live Moviemaker. Both applications will initiate camera playback, but the capture always fails.
rockitman187
  • 2559 Answers
SOURCE: Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Posted on Jan 29, 2009
mxg6999
  • 7 Answers
SOURCE: CAMERA DOT CAPTURE TO LAP TOP
Make sure your camera is set to Play/Edit mode.
Posted on Sep 08, 2009
  • 497 Answers
SOURCE: Sony DCR-HC52E connected with Firewire not detected in moviemaker
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 15, 2009
  • 497 Answers
SOURCE: i want Sony DSR-PD170 usb driver free downlod for
Option 1:
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Posted on Oct 01, 2009
SOURCE: Sony MiniDV DSR-PD170 won't playback recorded video
the tape path of the camera needs to be adjusted ,so you need to get that fixed.
regards
Posted on Mar 24, 2010
I'm trying to capture video from my sony dvcam dsr-pd170 onto my laptop but can't a wire that will hook up the two devices together. What type of cable am I looking for?
Hi, you have a choice of USB (If you are on Win XP or older Windows) or Firewire cable if new Vista or Win 7 okay? or you can use the standard Red/Blue/Yellow connector cables, 3 in camera, 3 to the PC, mostly these sockets will be on rear of PC close to Speaker socket.
Take care,
David UK
Jun 21, 2010 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony camera problem in detecting
check the dv ports pin are fine ... 4 pins should be visible ...
check dat out .
Sep 19, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Import video camera form JVC digital video camera Model #GR-D33U
you need a software video editing like adobe premier or sony to import video of video cam
May 21, 2009 | HP Pavilion dv9000z Notebook
Dvd burn erros
hi yar i m kishore frm andhra predesh ,india
adobe premier rpro is better then vista movie maker
there is no problem in making videos.
we can give more effects in that.k try it.
ur's kishore chowdary.
else save the video file into hard disk then write into dvd by using
nero,alchol etc
ur's kishorechowdary
+919441133420
May 04, 2008 | Microsoft Windows Vista Ultimate Edition
Sony DSR-PD170 Color Problem
sounds like a problem with the image sensor, or an intermittent cable connection to the sensor.
Jan 06, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony DSR-PD170 - playback problem
problem is caused by a defective image sensor block.  check with Sony; you may be covered under warranty.
Oct 12, 2007 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
125 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
