Question about Channel Plus MDS-6A Amplifier
What is a good reciever to hook up with this amp?
How do you hook zpa100 amp to audio source equilizer
No idea. Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Mar 04, 2014 | Pyramid Car Audio & Video
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
Need a wiring diagram for the gta4...please advise.
im not to familar with your amp but iv wired a lot of amps. You should just have your power ground remote and your sound. For your 12v+ You should not use anything less than about a 4 gauge wire fuzed and ran strait to your battery for this hook up your ground wire is to be no futher than a foot from your amp grounded to the vehicles chasis not over painted surface but a solid metal to metal contact with a good fitting for you connection on both ends. Then of coarse your remote which is labeld remote on your amp it is the only power source use to power your amp up and down it both completes the circuit and alows your amp to be manualy triggared with when you car reciever is on this remote wire is very important if you are doing the hook up your self you will want to make sure first that you if you have a factory radio in your vehicle to isolate that wire using a 12v tester. If you have an after market stereo in your vehicle such as a jvc kenwood alpine sony ect then you should have a blue wire with a white stip that is on the exsisting harness. That is your remote amp wire and it will tie in to your amps remote wire to power it up when the reciever is on or power it down when the reciever is off. My names Josh good luck with wiring the amp.
Mar 06, 2010 | Blaupunkt GTA 4 Car Audio Amplifier
Im trying hook up a subwoofer to my reciever and its getting power to the amp, however the amp is not powering on.. do you have any idea?
did you hook up the power antenna or amp. turn On wire? make sure you should ha a wire that is to power an antenna and this is the wire that has 12 volts as soon you turn On your stereo and send 12 volts to your amp. but if you don't connect this wire, the amp will never turns On
Jan 04, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
No sound
What brand of reciever are you using. Most pioneers have a floating signal ground and the shield of the input at the amp needs to be connected to chassi ground. Also if you had a previous amp failure and the power ground in your old amp opened the current to power the amp will flow through the signal ground of the reciever and burn the copper trace on the circuit board in the reciever. test this by connecting signal cable shield to car reciever chassi.
Aug 29, 2009 | Kenwood KAC-8401 Car Audio Amplifier
Wiring issues
ok here is how it goes power wire from the battery all the way to amp..then ground wire from amp to a good ground on car then the remote wire which you have to run from the amp to the back of your stereo which in most cases is blue then hook subs from the sub box to the amp
May 30, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Hooking up Turntable to Yahama HTR-5660
you have to have a pre amp, or an old reciever with a phono input.
you dont have to use the aux input, the cd or md-cdr inputs will be fine, but you do need that preamp for that reciever
Nov 29, 2008 | Yamaha Audio Players & Recorders
How to hook up an amp to a reciever without preouts, can it be done?
yes, you can have output signal at tape monitor output terminal and can be hooked to any amp.
Sep 04, 2008 | Audio Players & Recorders
The word unlock is displayed on the amp
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C216020&sliceId=1&sonymodel=STRDG710&sonyregion=US&sonytemplate=1&product=SG_STRDG710_5_8023&fes=true
Nov 19, 2007 | Sony STR-DE675 Receiver
Channel Plus MDS-6A Amplifier Logo
20 people viewed this question
Top Channel Plus Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Channel Plus Audio Player and Recorder Expert? Answer questions, earn points and help others
