Question about Garden
My homelite chainsaw has fuel blowing out the air intake, what causes this?
  • 3,740 Answers
There is a torn diaphragm inside the carb. If you pass me the model number I can find the parts you will need to repair it yourself.
Thanks for choosing FixYa,
Kelly
Posted on Mar 23, 2011
I have a Homelite 45cc chainsaw that spits gas out of the carburetor intake. I have thoroughly cleaned out the carburetor. Also engine revs very high when it briefly turns on, then it dies.Any ideas
Carb needs some serious cleaning. Best to soak it in a dip for a day or so then remove, rinse, blow dry and reassemble. If that does not do the trick your only option is to replace it. Those things can be a royal PIA when they go bad.
Sep 30, 2016 | Homelite Garden
Homelite Timberman 45 chainsaw runs fine but will not idle. Ideas?
dirty carb specifically in the idle jet turn it in till it bottoms . do not force more then return to the same place it was set if 3/4 turn in turn out 3/4 see if it works better .
Feb 16, 2015 | Homelite Garden
Carb filling up with fuel when its not running
The "ONLY WAY" fuel can pour out the carburetor is because the needle is being held up off the seat inside of the carburetor. A piece of trash is most likely causing this. Remove the carburetor, disassemble it, remove the needle and blow compressed air into it to see if it will clear it out. George
Oct 07, 2013 | Homelite Consumer Products 9.0 Amp, 14 In....
How to service homelite chainsaw
I take it you have a gas powered saw. Before starting any work on the machine, remove the plug lead.
To service it, remove the blade and guide and clean them all thoroughly. Clean the drive sprocket and its recess, this is best done with compressed air or at least a stiff paint brush. Inspect the chain cutting blades for damage and also the guide links and the groove they run in. Lubricate everything lightly with a thin oil before reassembly.
Check the spark plug, clean it thoroughly (not on a rotary wire brush) or replace it. Clean the air filter by blowing it with compressed air or a vacuum cleaner. If it is too soiled, replace it. Drain the fuel from the tank and check the fuel filter in the fuel tank and clean it if it appears to be dirty or contaminated. Blow the cylinder and the head cooling fins clean with compressed air, this can be done with a brush, but will require the cooling duct to be removed.
That is about all that can be done on a cursory service, anything further will require stripping the carb and removing the exhaust, neither really necessary unless a problem is being experienced. Everything is relatively simple to carry out and should not take too long. Please rate this response.
May 20, 2011 | Homelite Garden
Trimmer starts up when the air intake on the carburator is closed, once you put the air intake to the second position (which is introducing additional air into the carb, the trimmer stalls.
Its running far too lean, start by replacing the fuel filter on the end of the fuel hose, check the fuel lines foe signs of leaking, if no better, remove the carb, under the alloy pump, cover held with a single screw you will find an internall fuel screen, make sure this is clear.
May 01, 2011 | Homelite Garden
Homelite 16" 33cc chainsaw. Sarts but win't keep
Hello rick.... Get an aerosol can of starter fluid at your local autoparts store. Also get an assistant. Remove the air filter and start it up. Have your helper squirt some starter fluid into the air intake to keep it running for a couple minutes until the partial blockage in the carburater clears. Joe
Thanks for choosing Fixya!
Mar 12, 2011 | Homelite Garden
Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Jul 13, 2010 | Homelite Garden
Chainsaw reving full,not the idle screw or throttle cable
Remove the air cleaner assembly so that you can see the action of the throttle mechanism. If nothing around the carburetor throttle arm is broken or out of place (the return spring), then remove the screws in the throttle trigger part of the handle and look for sawdust blocking throttle trigger action. Hope this helps!
Jan 23, 2010 | Homelite Garden
Homelite 330 chainsaw kicks back hard, will not start
to isolate the problem, try a shot of starting fluid in the mouth of the carb with the air filter removed.if it starts then itd a fuel problem. If it still does not then take the plug out and look for a proper gap and or metal filings in it.If the plug is clean then it most likly is a partially sheared flywheel key causing it to fire off time.If all this fails to remedy the question it could be your ignition module has an internal problem causing it to fire at the wrong time. The most common problem I see on the old 330's is the intake manifild boot is all cracked or mushy and leaking air into the combustion chamber.It is visible if you remove the carb abd look inside.. good luck
Nov 05, 2009 | Garden
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
