Question about Kenmore Washing Machines
Freezer cold fridge not found no air flow. took apart and found evap frosted up bad. checked heater with meter and it has continuity. do not want to just start replacing parts. Does it have a timer or t-stat or is it all part of circuit board. it is a kenmore 75083 freezer on bottom thank you
  • 4,070 Answers
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Mar 22, 2011
Refrigerator is hot but the freezer is cold
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 12, 2013 | Sub-Zero 650 / O Bottom Freezer...
Freezer is working properly but fridge is not staying cold?
is the fan on in the freezer?? if not then you need a new evap fan..also check to see if there is frost build up on the back panel in the freezer section if so then you have a defrost issue could be a bad heater..to bandaid the problem..defrost the freezer back panel so air can flow into fridge side, but you will need to address the problem within a week or it will build up again
Apr 05, 2012 | Refrigerators
Kenmore refrigerator Model 253-68232800 will not keep food cold in fridge and frost build up in freezer.
Top of Form
Sep 14, 2011 | Kenmore 64722 Top Freezer Refrigerator
Hi, I need to know how to get the fridge to get cold because the freezer gets cold. I have the Whirlpool WBM451IX. Please Help
Top of Form
Sep 08, 2011 | Refrigerators
12 yr old kenmore top freezer. Freezer get real cold but does not freeze. Fridge part does not get very cold. I cleaned all the dust from coils, fan runs and all the seetings are good.
Top of Form
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
MOD: JS42PPFXDB00. Freezer is cold, but fridge is not cooling. A little frost building up in freezer.
Do you see frost built up on back wall of freezer if so it is not defrosting and this is what needs to be checked, remove back wall of freezer and check these;
Defrost heater-- it usually is at bottom of the evap. coil, to check it remove wires to it ,use a meter set to the lowest ohms setting and check for somewhere between 10-50 ohms if that is what yours is its good if meter reads OL replace defrost heater
Defrost thermostat-- if clips to the top of the evap. coil and is metallic,round , about the diameter of a quarter with a plastic side with 2 wires coming from it(do not confuse it w.thermister),remove wires and check for ZERO ohms WHEN TESTING IT MUST BE COLD so check it when frost is built up,IF meter reading is OL (WHEN COLD) its the problem
Defrost timer or defrost control if has digital display to show tempature
check timer(it could be anywhere except in freezer) by turning till you hear a click,the defrost heater should come on within 5 minutes if the heater does come on the timer is the problem and needs to be replaced,if the heater does not come on the above mentions parts (heater/t-stat) will be the problem.
defrost control is hard for unskilled lay persons to check SO IF heater and defrost t-stat are good replace control
Aug 03, 2011 | Jenn-Air Refrigerators
My Freezer on the GE Model No. GSH25JSXNSS is or had frost build up and it seems like the fan just keeps going? There is nothing up against the back of the Freezer blocking air flow so there is good...
To start a check shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
Jul 30, 2011 | General Electric GSH25JSXSS Stainless...
Fridge model 4244 getting too cold
Top of Form
Jul 08, 2011 | Samsung Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint
This more than likely is because your evap.coil is frosted up do to a part failure with the defrost system. Look at the freezer back panel is there alot of frost growing all over it this is the number one sign. Either way take the back panel off and make a visual check. If there is alot of frost first get a multimeter and set it on Ohms with alert chime meaning you get continuity. First check the defrost heat if you get the chime sound from the meter or NOT a infinite number of Ohms then its good. Then look for the round shaped part hooked to the evap and in series to the heater this is the bimetal (while its good and cold) cut wires to it and strip ends and check for continuinty there also if so, it's good but must be frozen cold to get continuity wire nut it back after check if good. If those parts check out then your mechanical defrost timer is bad or adaptive defrost board is bad it would be either one depending on this model of fridge you have. Hope I helped.
Jan 21, 2008 | Freezers
Washing Machines Logo
61 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
