Question about Acer Computers & Internet
I cant start my aspire 5532. when I turn it on it says "window failed to start status:0xc000000f, what can I do? I am using my sons laptop at the moment.
  • Tracy Hodgson
    Tracy Hodgson Mar 22, 2011
    Did not work, so it looks like I have to take it to someone. Thanks anyway. :(
    Scholar:
  • 58 Answers
This error means that there is either a problem with the files that Windows uses during startup, or a problem with the hard drive itself. You would have to have your laptop looked at by a professional to determine if there is an error with the hard drive, so for now, we will assume that there is a problem with Windows.
Immediately after you start your computer, press and hold the 'alt' key and tap the 'f10' key a few times. Your system should boot into Acer eRecovery. This will allow you to restore the operating system to the factory default install. In order to restore to factory settings, you will need to enter the password created when eRecovery was first started. (If you do not know the password, the default is '000000') It will take anywhere from 5 to 20 minutes to reinstall windows.
Posted on Mar 22, 2011
Testimonial: "thanx, i will give it a try. and get back to you. "
  • 519 Answers
Hi tchadwick59,
There are a few things you can try before resorting to reinstalling your operating system, namely Windows, from scratch.
Firstly, have you tried using the F8 key option to load Windows files which started your laptop successfully before? If not, simply press the F8 key once or twice after the initial POST screen.
This will bring up a menu with various boot options, i.e. safe mode, safe mode with networking etc.
One of the menu options is to boot with 'last known good configuration'. Highlight this option & press enter. This should start Windows correctly as it loads a set of Windows files from a back-up of your last Windows settings which worked correctly.
If this does not solve your problem you will have to perform a system repair by inserting your Windows disk & following the prompts to repair your Windows installation.
Let me know if you need any further assistance resolving your problem.
Best wishes,
Graeme.
  • Juju0105090 Jul 26, 2011
    Hi I have the same issue. I did the steps but it take me back to that same windowds boot manager screen. I do not have am option to put the disc in since my laptoo is a mini....whats the alternative?
  • Graeme van Malsen
    Graeme van Malsen Jul 26, 2011
    You can use a disk by plugging in an external CD or DVD writer to a USB port and setting it as the first boot up option in your Bios settings. Alternatively, you can copy your Windows disk to a flash stick and boot from there.
    Feel free to contact me should you need any more details.
I keep getting error code 0xc000000f on my asus laptop and don't have the start up disc
Solved] Fix Windows 8 Boot Error 0xc000000f go here for instructions http://www.smartpctricks.com/2013/09/solved-error-code-0xc000000f-windows-8-a-required-device-isnt-connected-or-cant-be-accessed.html
Sep 30, 2014 | ASUS Computers & Internet
Google com
Possible hdd failure or a damaged file.
Windows Boot Manager
Windows failed to start. A recent hardware or software chance miht be the cause. To fix the problem:
1. Insert your windows installation disc and restart your computer.
2. Choose your language settings and click "Next."
3. Click "repair your computer."#
Status: 0xc000000f
Info: The boot selection failed because a required device is inaccessible.
Aug 04, 2014 | Acer Aspire Computers & Internet
System will not boot up says windows failed to start. A recent hardware or software change might be the cause. To fix problem insert installation disk and restart however there is no disk or disk drive....
Sometimes updates can cause problems with the OS and thus using the Repair potion of the Operating System Disc is necessary. You may have re-install the operating system again. The problem, if you did not back up the drive, you will loose all data and programs.
Feb 17, 2018 | Acer Aspire One D255-2509 Atom N450 1
Status: 0xc00000e9 acer vista faulty hardware
You didn't supply the Make, Model of Laptop or the OS you are using?Remove ALL media, CD, DVD, USB, Unplug , remove battery, plug in , If you can do a restore/recovery procedure. If that fails, open the laptop and reseat the HDD and Memory Mods. I don't know how old your laptop is , Can you open the BIOS? Is the CMOS battery good? Have you tried a OS Repair Disk? Need more info, have you seen this: http://answers.microsoft.com/en-us/windows/forum/windows_7-system/unexpected-io-error-has-occured-status-0xc00000e9/ca21de58-4b0d-4f4c-b110-3788fd534e8a
Dec 20, 2012 | Computers & Internet
Aspire d257 Info: the select entry could not be loaded because the application is missing or corrupt
If this only comes up during startup? Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 23, 2012 | Acer Aspire One D257 Netbook
Advent 4213 0xc000000f Error
Download this tool and make a USB Windows 7 Installation drive.
http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
A free legal Windows image can be downloaded. Check the MS Product Key sticker for what version your system came with. You may have to use your key. IT MUST BE THE SAME VERSION.
Windows 7 Home Premium SP1
http://www.mydigitallife.info/official-windows-7-sp1-iso-from-digital-river/
http://msft-dnl.digitalrivercontent.net/msvista/pub/X15-65733/X15-65733.iso
Download correct version and burn onto DVD to use. In your case, you need a Virtual CD-ROM player like Magic ISO to make USB installer.
Not quick or even fast, but true.
Oct 21, 2012 | Advent Netbook
Windows failed to start, Status 0xc000000f acer aspire 4730z
aspire aspire d257 status 0xc000000f Info: the select entry could not be loaded because the application is missing or corrupt
Jun 30, 2012 | Acer Computers & Internet
Acer aspire 5532 is in loop wont boot error windows failed to start a recent hardware to software change might be the cause
Because of the power interuption the recovery partition has been corrupted, the hard drive will need to be formatted to use the recovery discs. Go to www.acer.com contact customer support and the technical department for additional help, they have one of the best support programs available.
Jun 28, 2012 | Acer Aspire 5532 Window 7 1.6ghz Amd...
Acer 5532 Touch Pad Not Working
Here are a couple of ideas from a Google Search:
Press the key to the left of the On/Off button. The key has a picture of a finger pressing the touchpad. So simple, so elegant, so little information out there about it.
https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/my-touchpad-on-my-acer-aspire-5532-laptop-isnt/51f5de30-b465-e011-8dfc-68b599b31bf5?auth=1
Dec 23, 2017 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Cant get my laptop to up load
Do you have any important files that you want to back up first?
If not using the restore function will be the easiest route.
Jun 13, 2009 | Acer Aspire 3680 Laptop
Computers & Internet Logo
269 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
