Question about DBX 2231 Home Equalizer
One channel ceased to work. Found transformer to be bad and replaced it. Turned unit on and the top circuit board at front off unit was getting hot and a burnt odor appeared immediately. Found a capacitor blackened and also found U15 chip some discrepancies from other I.C's of same kind when checked with a tracker device. No schematic available . What is U15 (JRC-45600). Any information would be greatly appreciated
  • 4,234 Answers
The part is a 4560 (generic opamp IC. The damaged IC is more likely to be the symptom not the cause Remove the IC and the cap. Replace the cap, but not the IC and measure pins 4 and 8 to ground. These should be the power inputs and measure +/- 5 thru 12 volts. They should be equal but opposite. Should htey be different, check the power supplies or any filter caps.
Update this with the results.
Thanks,
Dan
Posted on Apr 07, 2011
Freezer is frosting up and cold air not getting to refrigerator below.
You will have to defrost the freezer it is froze up were the air will go to the fridge.
Mar 26, 2016 | Refrigerators
How to fix my garage door opener?
I'm assuming you mean that it won't close, only open? If that's the case then your eye beams may need to be adjusted. The wall button can override the sensors whereas the remotes can not.
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Behringer EP2500 drawing large current when powered up
If you are pulling the transistor that drives the final and the problem goes away, is the driver bad? Is the power supply a multi channel isolated unit? Could the channel for that side be bad?
May 18, 2013 | Behringer EUROPOWER EP2500 Amplifier
Onkyo HT-R500 no display
Look on line for service manual. Display problem is usually traced to 1, or more, of 3 resistors in the AC supply to the display. It appears that the resistors are supposed to be 1/2 watt but the one I removed from my unit was only 1/4 watt. The resistors are mounted on a small board mounted on the front side of the main transformer - right most board. I had to unscrew the transformer to access the resistor. I looked at voltages coming out of the transformer and the the same voltages leaving the circuit board. There is a 1 Ohm, a .47 Ohm and another that supply AC voltage to different parts of the display. I found one resistor open. Replaced it and I now have an operating unit.
Feb 14, 2012 | Onkyo HTR500 Receiver
I cleaned my io breeze quadra plates with rubbing alcohol reinserted and turned it on, it made some crackling noises and started emmiting a burning smell like a hot transformer pulled insert plates found...
You will need to take unit apart to check both the and bottom. Start either at top or bottom go over the circuit path of hi voltage grid wire check for more burn marks. Insure hi voltage insulated wire coming from transformer is not broken. This will be located at bottom of unit you will have to take top pc board off and control transformer to get to hi voltage transformer, then when that is removed you will see the hi voltage connector I was talking about. That wire is soldered on and is a very delicate connection. Make sure wiring soldered. Hi voltage transformer should be ok if you did not leave unit on for a long time while you had your loose connection in the grid wire.
Dec 14, 2010 | Sharper Image Professional Plus Ionic...
Vsx-816-k left channel cuts in and out.
You likely have a cold solder connection on the circuit board. Inspect the board for loose connections for the left channel - use a non-conductive pointed object and poke the board on several places while the unit is power-up. Be careful not to get electrocuted. Compare it to the right channel circuit - they are almost identical. If the unit recovers the left channel while poking, then you have found the bad connection. Re-apply solder to that junction - make sure you've dis-connected the power and dis-charged all caps before you touch and repair the circuit board.
Nov 09, 2010 | Pioneer VSX-816-K/S Receiver
Unit won't power up completely
The clicks you hear are the relay that completes the circuit for 110V AC to the main power transformer. Mine had the same problem and here's how I've gotten it to work. A lightning strike near our house caused it to fail, and I traced it to the power transformer relay activation circuit. The tuner and amp were fine. I found a bad transistor in the relay circuit, but didn't have a replacement on hand, so I soldered a jumper wire across the relay switch connections on the power transformer circuit board. This connects the 110V AC directly to the power transformer. DC Power to the amp and tuner circuits will still be controlled by the power switch, but the transformer will be supplying all the AC voltages to the main board. If there is a real problem with the circuits that load the transformer or the transformer itself, then the fuse will blow. If the fuse doesn't blow then I suspect the problem is just in the power sequencing circuit itself, that is not needed for operation other than to make the unit "Energy Star Compliant". A lot of electronic items have a transformer that is not switched, and only fused, so that the supplies are available at all times.
Jan 24, 2008 | Audio Players & Recorders
Marantz SR18-no sound
I have worked exclusivly on marantz recievers, for the last seven years, the loud 'pop' you heard, and smoke, was 90% that one of the amplifier channels, on the amp block, has blown, and consiquently the unit stays in protect mode. It will power up, and decode audio, and even show an f.m. stereo on the tuner, but you won't get the 'happy click' of the protection relays, until the channel is repaired. also replace the 5fd memory capacitor on the front micro board behind the front panel. If you have someone repair the channel, make sure that the tech resolders all of the connections on the molex connectors on the amp block. there are 10 of them, five male and five female, The bad solder on these are what caused the problem in the first place.
Nov 29, 2007 | Marantz SR-18EX Receiver
Proton Model RS-420 clock radio lost power back-up
The battery is located on the display circuit board at the front of the unit. It's a bit of a pain to get to.
You'll need to open the case, unplugging the wiring harness plugs so you can take the two halves apart. Next, remove the strip of circuit board at the top where the snooze/alarm and other top button switches are. Then you will be able to get to all of the screws holding the display circuit board to the front of the case. The battery is soldered to the board. I'm not sure what type or voltage it is, but it's probably a single-cell NiCd at 1.2v. I think the best replacement would be a supercapacitor but I need to figure out exactly what the battery is first.
It's a great radio that's worth fixing. If anyone can tell us what the battery is, please post! Mine says "860" on it.
Cheers,
- Phil
Apr 30, 2007 | Proton R5A Clock Radio
DBX 2231 Home Equalizer Logo
275 people viewed this question
Top DBX Audio Players & Recorders Experts
Chickenwatt
Level 1 Expert
Themcramers
Level 1 Expert
Tom Chichester
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
