Question about Toshiba TW56X81 56" Rear Projection Television
Need a bulb for a Toshiba RPTV, model TW56x81, but can't find the part number?? Thanks
  • 84 Answers
Toshiba 23003818 Picture Tube Assy, Coupling, B [V903b] Toshiba 23003781 Picture Tube Assy, Coupling, G [V902g] Toshiba 23003817 Picture Tube Assy, Coupling, R [V901r] Here's the part numbers for each of the CRT's. This set doesn't have a single bulb like you mentioned. Your problem is most likely elsewhere in the power supply or Horizontal output circuit. Good luck
Bill W
integrityhomeworx.com
Posted on Mar 23, 2011
52WM48P Rear projection TV Lamp fitting
Original brand Toshiba lamp ,unit price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 13, 2014 | Lapbix Tv Lamp For Toshiba 52wm48p 120...
Toshiba 56hm195 tv picture freezes
Check to see if using HDMI input and if so try component input and also advise me if using box of some sort.
Mar 12, 2012 | Toshiba TW56X81 56" Rear Projection...
I have a 4 year old Toshiba-56HM195 with blueish haze.I have place the engine light 3 rme in 3 year bulb 3 time in 3 year it's been a year seen I dn it which one is going out .
Yuor covergence board is bad and you need to have a tech replace the convergence IC's on the board and bad electrolytic caps, or buy a new one at www.partstore.com
Nov 26, 2011 | Toshiba TW56X81 56" Rear Projection...
Toshiba TW56X81 power LED blinking ,tv won't turn on
Try unplugging and waiting about 2 min. Then retry. There is a self protection circuit which is what is stopping the unit from coming on, but it can be triggered by many things. [Units this old are famous for the capacitors (electrolyte dries out and then they blow), but that is just the most common problem. I would look the capacitors over and see if they give any indication of being "blown" (discoloring, etc.) and replace them if they do.
Oct 17, 2009 | Toshiba TW56X81 56" Rear Projection...
Toshiba tw56x81 plug it in and it makes a
you have freid the fuse inside it its a cheap and easy fix i have anserd 3 allready todsay on this problem it is very common and under £50 to fix
Sep 19, 2009 | Toshiba TW56X81 56" Rear Projection...
Replacement bulb
There are numerous sources on line which will find the right replacement bulb based on your model number.
Jun 14, 2009 | Toshiba 52WM48 52 in. HDTV-Ready...
Toshiba tw56x81 rear projection tv "protection fault"
Jan 04, 2009 | Toshiba TW56X81 56" Rear Projection...
Toshiba 50H82 hyperboard caps
Service manual won't help much in the hyper board and that's likely the problem.. Simply remove the hyper board and open the can. Inside you'll see a number of smd caps. There are 11 10mf/16v that need to be replaced...
Bill
Jul 26, 2008 | Toshiba 57H82 57" Rear Projection...
Wobbly lines on my Toshiba TW56X81
This sounds like a input problem. The source of the signal may not be well matched to the expected input spec. To test, see if the "SETUP" menu items are clear. If so it is something to do with a cable, connector, or configuration of the source.
Mar 12, 2008 | Toshiba TW56X81 56" Rear Projection...
Toshiba TW56X81 Convergence issues
I retired from the TV repair business because if you are not an authorized repair service center most manufacturers will not even talk to you. If you are electronically inclined you can repair this tv. your problem is a bad convergence ic. you need to be able to locate it and replace it. it probably has about 15 or 18 legs that need to be unsoldered and a new replacement re-installed
Sep 29, 2007 | Toshiba TW56X81 56" Rear Projection...
Toshiba TW56X81 56" Rear Projection Television Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
