Flashing F23 error code (Service light also indicating), stopping partway into cycle
    Brigadier General:
  • 6,277 Answers
Sorry,you do not say the make and model of your particular machine but try this- I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 22, 2011
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
F23
PRESSURE SWTICH ERROR
The wash level and level heater safety are switched on at the same time F23
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to pressure switch and Central Control Unit (CCU).
3. Check connections of the CCU board within the housing.
4. Check the pressure switch for worn or failed conditions .
cheers
Jul 18, 2017 | Whirlpool WFC7500VW Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
I keeg getting the dreaded F11 anf DL code!
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Have just got new whirlpool aqua steam washing machine and it keeps stopping with the code f 23
F23 codes indicates an electronics communication problem with the washerThe following list of codes indicates an electronics communication problem with the washer. To remove the error display, press Pause/Cancel twice.
Jul 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
