Question about Optoma PK100 Projector
I have a Optoma projector and no laptop, but we do have computers. Is it possible to connect the both. How
  • 113 Answers
If your computers have VGA connectors (usually blue coloured) you can take that out of the back of the computer and plug into the projector.
Posted on Mar 22, 2011
Optoma EZ Pro does not connect to laptop. Tried Control Panel / connect to laptop / dual display, but computer will not recognise projector.
reload software and reboot entire system after make sure Optoma power is turned on before turning on computer
Jul 21, 2010 | Samsung Computers & Internet
I own a Optoma EP709 dlp Projector and have had no problem until recently. I have used a hp laptop Vista based computer. I can no long toggle (fn F4)successfully so that the view is shown on the projector...
this is a shot in the dark, i don't have a projector to hook to my laptop, but i have hooked it to my tv and actually had to right click on the desktop in an unoccupied spot and go into the display settings to get my connection between both, it is probably similiar for laptop to projector.
May 20, 2010 | Office Equipment & Supplies
Problem connecting Optoma projector model EP731
Check the resolution of your computer and make sure that your projector is compatible with the same resolution.
May 07, 2010 | Optoma EP730 Multimedia Projector
How to connect the Optoma Pico PK-101 DLP to a laptop
You have to buy a 17€ converter.... here on my website, is a diagramm on the B chapter that explain a lot.
http://shadar.spacequadrat.de/?p=121#more-121
Here is the link to buy one converter
http://shop.ebay.fr/i.html?_nkw=pc+VGA+to+converter&_sacat=0&defsort=15&LH_BIN=1&_sop=15&_odkw=pc+to+converter&_osacat=0&bkBtn=&LH_ClassifyToggle=0&_trksid=p3286.m270.l1313
Jan 05, 2010 | Optoma Pico PK-101 DLP Projector
Optoma Projector Only Displays White Screen
did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
May 12, 2009 | CTX Optoma EzPro 610 Multimedia Projector
My Optoma HD65 Projector stops starts working and
Possible cause is overheating.
Do you hear the fan working?
What happens when you use the lowest level light output?
Does it run longer?
Also possible cause is a faulty temp sensor.
AC wire connection may not be firmly pressed in socket.
Mar 01, 2009 | Optoma HD65 DLP Projector
Projector can't connect to laptop
We just solved a similar issue. Most likely your PC or laptop is currently set to a display resolution that is too high for the projector or is one that it cannot handle. Try setting your computer display to 640 x 480 or 800 x 600 and see if you can get the projector to work. If it does, then you can figure out the maximum display resolution you can use. Also consult your projector documentation for supported resolution modes.
For the PICO in particular, it looks like those are in general for small mobile devices (320 x 240 or less displays), and the PK102 model has native VGA (640 x 480) support with extended support for 800 x 600. You will not be able to use this on most modern computers except at the lowest resolution setting for the PC.
Feb 19, 2009 | Office Equipment & Supplies
Projector to laptop
Your post:
  • cords/cables - would depend on what are the available OUTputs from your laptop. Some examples are DVI, 15pin VGA, S-Video and the single yellow RCA;
  • where - would depend on where you are, the DVI and/or 15pin VGA cable would be available from most computer shops, the S-Video and the RCA from most electronic, audio/video stores.
  • how to do it - would depend on the brand & model of your laptop. Normally it would be a combination of the Fn key + F? to enable the external video. Cycling through would yield, LCD only, LCD + external, external only. The F? would be dependent on what laptop you have. Connection wise, it would be a matter of connecting the appropriate cable to match the available output connector of the laptop to a matching INput connector of the Optoma projector;
  • Additionally, depending on the model of the Optoma (more specifically its resolution), it may be to your advantage to initially lower the screen resolution and screen refresh rate of the laptop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 20, 2008 | Optoma MovieTime DV10 Multimedia Projector
Unable to Connect DV10
Hello!
Which are laptops? I use IBM R40e and HP laptop and I usually connect them with DV10 for conferrence. It's well! I have just a problem with Asus EEE. It unable connetc with DV10. I try use Video jack to connect. Result: It can display but the quality is very bad. Now I try to find another way to connect them together. Some information to share with you. Thanks you!
May 03, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma PK100 Projector Logo
96 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
