Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Laptop lost (wireless) networking capability and control panel inaccessible
Laptop unable to network and other problems
Posted on Aug 03, 2008
Enable wireless capability
Certain models of Acer desktop computers are designed with wireless capabilities.
These capabilities can be added to an Acer desktop system that does not connect wirelessly with either an internal or external wireless card, depending on the computer's configuration.
When the wireless connection is not working properly, you can troubleshoot the issue yourself.
The troubleshooting process eliminates the problems that may be preventing the Acer desktop computer from connecting wirelessly.
Check to see if any other computers at the same location are able to connect wirelessly.
The issue may reside with the wireless router or access point.
Power cycling the router or access point may resolve this issue.
Verify that the wireless adapter is enabled.
Click the "Start" button, then "Control Panel."
Click "Network and Sharing Center," then "Change Adapter Settings."
If the wireless adapter is disabled, right-click on it and select "Enable."
Connect to the proper wireless network.
The Acer may be attempting to the connect to the wrong wireless network, or it may have lost its connection to the correct network.
Click the wireless network icon in the task bar.
Click the proper wireless network, then click "Connect."
Enter the network password (or WEP key) if prompted.
May 26, 2013 | Acer Aspire Computers & Internet
How to connect wifi in lenovo g575
In order to connect to a wireless network and the Internet on an IBM Lenovo machine, you must first enable wireless networking via your computer's operating system. Allow about five minutes to enable your IBM Lenovo computer's wireless capabilities.
Click the Windows logo in the bottom left of your screen. Select "Control Panel" from the menu. Click the "Network and Internet" icon in the Control Panel. Click "Network and Sharing Center." Right click "Wireless Network Connection" icon. Select "Enable." Enable Wireless via Switch Check your IBM Lenovo laptop for a wireless networking switch. It is usually on the front of the computer above the keyboard. Slide the wireless switch to the "On" position. Look for a wireless light on the front of the laptop. In some cases a light will come on to indicate that wireless networking is active. Other switches, when active, reveal a green strip of plastic.
Troubleshoot network connection problems http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-network-connection-problems Lenovo support http://www-307.ibm.com/pc/support/site.wss/migr-50402.html
Apr 02, 2013 | Lenovo G575-438343u Amd E-350 1.60ghz...
How do i turn the wifi on on my lenovo ideacentre b3?
Step 1:
Feb 24, 2013 | Computers & Internet
How to turn on wireless capability without using keyboard fn key in laptop
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
click start Control Panel - Network Connections - right click on 'Wireless connection'
(or similar) and click 'enable'.
right click on the network in the bottom toolbar select open network sharing centre
you should have the options to either connect or disconnect or set up a network connection
this will vary depending on your operating system
hope this helps
Sep 17, 2012 | Compaq Presario CQ-40 Laptop Universal AC...
Cannot get my new laptop to use my wireless connection to my adsl router- wireless g old laptop using xp no problem
For connecting new laptop using windows 7
Goto Control panel-Network and Internet--Click connect to a network on left side of pane--It should show all the wireless networks including your adsl router--Click connect it would ask for security key-Enter your security key for router-You should be able to connect.
If unable to find wireless network of router then try following steps.
> Turn off laptop
>Turn off router and modem (Disconnect power cable)
>Power on router first then laptop
>Then follow first method.
Thankyou
Sep 09, 2010 | Computers & Internet
How can I turn on the wireless capability on my Asus G60VX laptop? the switch on the front left is on and still nothing. trouble shooting says wireless capability is turned off. it was working fine untill...
I can figure out that your laptop runs Windows Vista. Go to Control panel, then Network and Sharing centre and then go to Manage Network Connections and see if the Wireless Network Connections icon is disabled, make sure it is enabled and not connected. Try disabling and enabling it again. If still no go, try to manually turn off the wireless switch and turn it back ON. Check the light status (if any), confirm the error message too. If still, it seems not to be working, then the internal switching might have gone bad. You need to get the laptop serviced.
Regards,
Arvind
May 25, 2010 | ASUS Operating Frequency 2.4 - 2.5 GHz...
Unable to make router wireless
To use a wireless network/connection you need to do.
1. Configure the router's wireless with SSID, WPA encryption etc.
2. Next configure the wireless card in the computer/laptop with the router's wireless settings so it can connect to the wireless router.
Please click on this link for my instructions on how to secure your wireless network, configure the wireless router and configure the wireless card in the computer/laptop :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 10, 2010 | 3Com Computers & Internet
How do I turn on my wireless capability Gateway MD2614u
There is no hard switch for the wifi radio in your laptop model. Look at the Function Keys and tap the key that enables wifi radio
Jul 30, 2009 | HP (319468-002) (319468002) 802.11b...
Can't connect 2nd laptop to wireless network
Did you run the setup wireless network wizard on both computers? If not try this first & see if it fixes the problem. You will find this wizard in the control panel of your windows o/s. Hope this helps.
Jan 22, 2009 | HP Pavilion dv6000z Notebook
Do not know how to turn the wireless capability of my laptop on
go to device manager and see if your wireless network adapter is enabled (right click)
then go to the network connection in control panel and run the setup internet connection then choose the wireless option
then just follow instructions.
hope this helps
Nov 10, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
