I have a honeywell st1700. A few days ago, i had to change the battery and ever since, when i switch on the power switch, both the heating and water system are activated. I am no longer able to switch one or the other off, as desired. Has anyone experience such a problem and solved it. If so, i would appreciate it if they could email the answer. Thank you
  • 1314 Answers
SOURCE: Frigidaire - FSC23F7DS - water dispenser not working but ice maker is
take out the crisper drawers and see if the water tank is frozen is the light on the dispencer lighting up when you depress the paddle and look up in the dispencer to see if the acuating paddis broken we will go from there
Posted on Feb 18, 2008
ericbrunswic
  • 88 Answers
SOURCE: ecs 945g-m3 motherboard power switch pin location????????
Mike,
I have found the manual for your motherboard, here is a link to the download from the manufacturers website.
I hope this helps,
Thanks for using FixYa,
Eric
Posted on Jan 21, 2009
muttandjeff
  • 359 Answers
SOURCE: 61 Gallon Rheem Water Heater is leaking!
TANK COULD BE LEAKING BUT NOT USUALLY @ TOP CK ALL FITTINGS VERY CAREFULLY AND BE SURE IT IS NOT ONE OF THEM
Posted on Feb 24, 2009
  • 252 Answers
SOURCE: need help programing a honeywell thermostat T8095A1002
Go Here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
Posted on Apr 10, 2009
SOURCE: 44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Posted on Oct 16, 2009
I have a honeywell rth110b thermo and the other day I noticed that the display was fading and it looked like the battery icon was showing so I changed the batteries and now the display is completely blank...
The manual does not have troubleshooting steps.
Check the battery polarity, and clean points of connection.
Otherwise honeywell.com has customer care number
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 07, 2017 | Water Heaters
Our heating and hot water keeps turning off
Sounds like a glitche in the thermostat. First, override the program & see if it does the same thing over the next few days.
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C central heating programmer fault
you may vae to enter a different "Mode" to change the time....also try removing the batteries for 10 minutes and then reprogram the thermostat again
Oct 25, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
No power
check transformer in furnace... thermostats get there power from it....not the room its in
Mar 15, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
193 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
