Question about Calibre Radar Detector
Remote will not turn k40 on have replace battery
2 Suggested Answers
  • 134 Answers
SOURCE: remote does not connect with unit built into car. does not go on
First, the K40 Calibre isn't a terribly good radar/laser defense system no matter what K40 claims. I would rate its radar detection capabilities as fair, and its laser jamming capabilities as poor. But on to your problem. Call K40 and see if they can talk you through any specific procedures which they have. It appears that your Bluetooth remote and the RD are not properly synced. Its best if K40 talks you through the resolution.
Posted on Mar 17, 2009
Where is Mercedes SL500 03 Driver side fuse box number written?.
Fuse Terminal Cable ID (fused) Fused function Rating in amperes (A) F1 30 - Wiper park position heater relay (K40/2kA) F2 30 - High pressure and return flow pump relay (K40/2kF) F3 30 - Steering column forward/back adjustment relay 1 (K40/2kD)
Steering column forward/back adjustment relay 2 (K40/2kE) F4 30 - Steering column height adjustment relay 1 (K40/2kI)
Steering column height adjustment relay 2 (K40/2kJ) F5 15R - Wiper On and Off relay (K40/2kH) F8 30 RD 0.75 Central gateway control unit (N93) F9 30 PKWH 2.5 Left door control unit (N69/1) F10 15 BKVT 0.75
BKVT 0.75
BKVT 0.75 Left front headlamp unit (E1)
Right front headlamp unit (E2)
Xenon headlamp control unit (E1n1, E2n2) 15 RDGN 0.75 Restraint systems control unit (N2/7) F11 15R BKYE 1.0 Circuit 15R/30 cutoff relay (K75) F12 15R - Spare F13 30 RDGN 1.5 ABC control unit (N51/2) F14 15R BKGN 0.75 Windshield washer fluid pump (M5/1) F15 30 RDGN 1.0 Data link connector (X11/4) F16 15R PKYE 1.0 Valid for code (855) TELE AID:
D2B telephone and TELE AID transmitter/receiver (A35/17) 15R PKYE 1.0 Valid for code (853) MB standard telephone:
D2B telephone transmitter/receiver (A35/13) F17 15R RDYE 0.5 Vehicle-sensitive seat belt lock sensor (A60) F18 15R - Spare F19 15 BKYE 1.00 Valid for engines 112.973, 113.963/992:
Fused via circuit 15 connector sleeve (Z3/29):
Cylinder 1 ignition coil (T1/1)
Cylinder 2 ignition coil (T1/2)
Cylinder 3 ignition coil (T1/3)
Cylinder 4 ignition coil (T1/4)
Cylinder 5 ignition coil (T1/5)
Cylinder 6 ignition coil (T1/6)
Cylinder 7 ignition coil (T1/7)
Cylinder 8 ignition coil (T1/8) F20 15 BKGN 0.75 Data link connector (X11/4) F21 15R BKYE 0.5 Instrument cluster (A1) F22 30 RDYE 0.5 Instrument cluster (A1) F23 30 RDWH 1.0
RDWH 1.0 AAC [KLA] control and operating unit (N22)
Coolant circulation pump (M13) F24 30 RDWH 0.5 Stop lamp switch (S9/1) F25 30 RDYE 0.75 Alarm signal horn (H3) F26 30 RDBU 0.5 Lower control panel control unit (N72) F27 30 RDVT 2.5 Left front seat adjustment control unit with memory (N32/1)
Apr 22, 2015 | 2003 Mercedes-Benz SL-Class
Replace lead wire on k40 antenna
the coax doesnt solder it screws in twist the replacement wire clockwise to secure it they have it ehow tech its a website because I had the same question
Aug 17, 2012 | K40 57.25 Base Load CB Antenna Kit with...
My K40 unit keeps beeping 2X every 10 seconds or so.. It still goes off when radar is present but it wont stop beeping. any insights would be helpful
You have a K402000 radar system. The double beep is a rear receiver disconnect notification. If you go to the K40 website and access their dealer locator from the dealer section, you can find an authorized dealer to help you with this problem or you can call K40 directly and speak to them...they really are a great company to deal with.
Aug 20, 2011 | Calibre Radar Detector
Have k40 antena in my 29 ltd cobra and i cant get less then 1/2 mile signal
Hi, my name is John. A K40 is a great antenna. Make sure you have it in a good place, such as top of vehicle, a good ground, and SWR checked, they can check it for you free at Radio Shack or CB shack.....if that does not do it, let me know, it could be something internal....hope this was helpful....
Aug 29, 2010 | Cobra 29 LTD CB Radio
My K40 Undetectable seems faulty
the on board diagnostics is telling you the rear sensor is bad or disconnected
Aug 20, 2009 | 2000P Radar Detector
Remote does not connect with unit built into car. does not go on
Mar 15, 2009 | Calibre Radar Detector
Calibre Radar Detector Logo
439 people viewed this question
Top K40 Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a K40 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
