Question about Philips 190B6CB/27 19" LCD
Volume control appears on screen uncommanded and cannot be sent away
As described, the volume control box appears on the screen without volume buttons being pressed and remains there. Attempting to reduce the volume results in it increasing to 100% once the button is released, making me think that the volume increase signal is being sent somehow. Pressing 'ok' does not send the box away, disconnecting cable does not help, cycling power with power button has no apparent effect. Disconnecting power cord fixes the issue for a few seconds, whereupon the box appears again.
  • Tim Wilson Aug 03, 2008
    I should have been more clear - the problem is with a Philips 190B7 LCD computer monitor.
  • Tim Wilson Aug 06, 2008
    Thanks to everyone who offered advice - it turned out to be under warranty, so I shipped it off to Philips and they sent me a new monitor. However if it does the same thing after the warranty expires I'll definitely try the circuit-board solution.
I had exactly the same problem. The volume up button was constantly on, causing the on screen display to be permanently displayed. Here is the solution to fix it. This will also work for any other front panel buttons that are misbehaving.
Note: If you monitor is still under warrantee, don't try and fix it yourself - just send it back.
If you open your monitor you will find a small circuit board with a row of microswitches mounted on it. This is the circuit that's causing the problem.
To open your monitor you will need to remove the stand (one plastic cover that unclips by hand and 4 screws that can be removed with a philips screwdriver). This will then reveal two additional countersunk screws that need to be removed.
You can now remove the front cover. There are 4 clips at the base of the cover that can be removed by hand. You then need to pry the cover off, starting at the corner next to the power button. This is really quite stiff and you need to use a reasonable amount of force. Don't worry about the loud cracking sound as each clip along the side releases.
Once the cover is removed you will see the circuit board with the microswitches staring you in the face.
This board needs to be replaced but if you want to fix the problem immediately here is what I did.
Disclaimer - Proceed at your own risk from here on in.
Plug your monitor back into the power and reconnect to your PC. Make sure it's on and still showing the same problem.
The curcuit board unclips and there is a 7 pin connector that also can be unclipped. Remove the board and undo the connector. You don't need to switch off the power.
After the board has been removed for a few seconds, the on screen display that was permanently visible should disappear.
Now I temporarily disabled the malfunctioning button by bending the associated pin on the connector 90 degrees and then reattaching the connector.
How do you know which pin is associated with which button. Trial and error. Simply bend down a pin, and reattach the connector. If the problem persists, unplug and try the next pin.
When you've found the correct pin, straighten the others and reattach the connector.
Clip the curcuit board back in, making sure the connecting cable is clear and doesn't get pinched.
Reassemble your monitor and you're good to go.
The next step is to order a new circuit board from Philips. These should be really cheap (I hope) and you now know how to fit it yourself.
I'm going to try ordering one tomorrow.
Mark Gladding
Posted on Aug 04, 2008
  • 1 more comment
  • Laura
    Laura Nov 21, 2013
    Check out a more likely and easily fixed solution:
  • Laura
    Laura Nov 21, 2013
    Also, go to page 11 of
  • Laura
    Laura Nov 21, 2013
    Above link has detailed pictures as to exactly how to safely remove monitor cover. I simply cleaned the applicable areas to fix. If you look at the area BEHIND the buttons you will notice that there is a cheap SINGLE piece of plastic which is used to press the individual buttons on the monitor. It's obvious that extra pressure on misalignment of this could easily cause a problem. :-)
Switch off the tv ,,if you have a remote control , remove the battery of the remote and switch on the power again..
If it works fien then the problem is in the remote control..
Posted on Aug 03, 2008
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
Suddenly my yamaha Rx-v2300 only works to provide sound at nearly full volume to get any sound at all. This then comes with a background buzz. This only occurs while getting cable TV signal, using other...
I'm assuming you have a cable converter box (set-top box) that you have hooked to your receiver. Check the box volume using the cable company's remote control. These boxes frequently have variable audio output, and if you turn the volume down on the box you'll have the symptom you're describing. When you press the volume up or down buttons on the remote, you'll usually see a volume bar on the TV screen. As you raise the volume, there may be a point marked by an arrow, which is where you should set the volume. On some boxes, when you get to a certain level the words "best stereo" appear, and that's where to set it. If your box doesn't have some indication like this just leave the volume set 3/4 or full up. Then the volume on the receiver should function properly with the cable TV input.
Jan 12, 2011 | Audio Players & Recorders
Menu screen appears constantly, volume decreases by itself
Hi, common issue with rca sets, you need to replace the tact switches on the front control board. If your not good at soldering / un-soldering you may be able to still purchase the whole control board, call a local tv shop with the complete model # and chassis # of your set and they can give you price & availability, video-tek
Jun 02, 2009 | RCA HD52W59 HDTV Projection Television
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Volume bar won't go away
Open Task Manager
Find "Volume Control"
End Task
Jan 07, 2009 | IBM ThinkPad R50e Notebook
Black box
Make sure your closed-captioning is turned off. This box appears when you have captioning set for "text" mode and the set is on a channel where captions are being broadcast. The TV blanks the part of the screen where the text would go, but there isn't any to display. Some TV's have a single button on the remote to turn captioning on, and it's easy to set the TV for captioning without knowing it.
Dec 18, 2008 | iLO Televison & Video
I have a black box that suddenly appeard in the middle of my screen. This takes up nearly hlf the screen and will not go away unless I hit the volume control or any other control. It then goes away for...
My parent's JVC did this as well. It took us a little while to solve it (and through searching for how to fix it, found this post).
Using the JVC's remote control, we pushed the C.C. (closed caption) button and cycled to the "OFF" setting. That fixed it. Using the TV's front panel setting did not fix the issue, we had to use the remote control.
Note: the "text" CC setting re-displays the black box.
Dec 16, 2008 | Televison & Video
Black square box appearing on screen
Mar 04, 2008 | iLO V27DMBX Television
Screen problem
check captions on your menu settings it has caption 1 and 2 if it is not set on caption it could be on text which cause the black box to come on the screen turn off every thing on the caption menu.if that does not work then take you set to a tech to have it reset then it could be your eprom or your video circuit.good luck.
Aug 28, 2006 | Samsung TXK2754 27" TV
Philips 190B6CB/27 19" LCD Logo
1,212 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
