Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
When I print avery label 74520 on my HP Office Jet Pro 8500, it prints too far to the left on the paper label.
    Master:
  • HP Master
  • 956 Answers
You have to setup printer details, not to sure of programme, if word try looking under mailings/envelopes. There you have the choice to alter the details of the item you wish to use as a template. Good luck.
Peter.
Posted on Mar 24, 2011
Why does hp officejet Pro 8600 crashes when printing avery labels?
Avery labels may be blocked on your computer so check your security settings. Other wise you may need to refresh the page, your computer or the printer. If that doesn't help you may need to double check your ink cartridges are full and correctly placed, also that the wires connecting the printer to your computer are all in properly.
Mar 01, 2014 | HP OfficeJet Pro K8600 Printer
Bifinett kh 831
go to file/print/properties, Paper/Quality Tab-if 74520 is not there, click on custom button, type in Avery 74520. size 4.30 x 11, save & click ok. exit properties then go back to file/print/properties, select Avery 74520 from list, then go to effects tab select print from document button which should show Avery 74520 in the text box to the right. click ok and print.
Jun 28, 2013 | Office Equipment & Supplies
Do I need specific software to print labels on my hp office jet all in one j6480? I can not even get started. I have been unable to find any specific place through Hp help that talks about printing labels....
You will need software like Avery label or Microsoft Word in order to run labels. Do you have a program of this nature on your computer? Give me an idea of what software you have and I can walk you through creating label. As far as the printer goes, you just need labels. We can create the template you need for the specific label you are using. Would you please provide the label number you are using so we can create the correct template?
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | HP Office Equipment & Supplies
How do you print labels on a HP Office Jet Pro 8500A Plus and align the labes on the sheet???
Depending which publisher you use look for mailings or envelopes it all in there.
Good luck
Peter.
Mar 07, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
How do you type and print Avery labels 74520? I have lost the instructions which came with the labels.
This can be done with settings through your word processing program. Assuming you are using Word:
Microsoft Word 2007
The newest version of Microsoft® Word now includes hundreds of Avery Templates for labels, business cards, dividers and more.
Find Avery Templates by selecting the Mailing tab at the top of the Microsoft® Office Word screen. Just choose Create > Labels > Options > Avery US Letter, then choose your template by selecting the correct Avery Product Code.
Access Pre-Designed Avery Templates that are available from Office Online by selecting the round Office button at the top left of the screen, selecting New and then choosing the Avery product type. Pre-designed templates for Avery business cards, greeting cards, dividers, labels, note cards and postcards are available.
Avery Wizard for Microsoft Office is a free download which inlcudes step-by-step instructions to format Avery labels. Trust this is helpful. :)
Dec 08, 2010 | HP Officejet 6310 All-In-One InkJet...
Our HP Office Jet Pro 8500 printer has a message stating there is a paper jam when there is no paper jam. How can this be fixed?
Check the following Steps for fix Hp printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Where can i find hp office jet 8500 print heads
Try staples or home depot if they are still open otherwise you have to order it from HP or you could try the new egghead. HP's address is www.hp.com
Mar 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Avery Ink Jet Magnetic Sheets - 3270
It worked fine for us on an Epson. We printed about 40 sheets fed one at a time. Do not stack the sheets in the feed hopper, they stick together because of the magnetism.
There is no template because the material is not die cut. It is just full 8.5x11" sheet size.
Feb 04, 2008 | Avery DesignPro Deluxe CD-ROM...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
561 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
