Question about Kingston 256MB printer memory for HP Color LaserJet CP1518ni Printer
Printer says cyan in wrong position i have double triple checked it is in right position
Replaced Cyan ink and now it will not recognize. Brand new cartidge
Did you use HP ink or generic? Generic inks will only be recognized if they have the chip that talks to the printer. That is not to say they won't work - you just will not know the level. If you did use HP you have to make sure you have removed the taped portions, and that it "clicked" when you put it in the cartridge. Also - double check you really put in Cyan, I have put in the wrong color in a slot and it will not recognize the cartridge - boy did I feel really silly that day!
Dec 04, 2015 | HP Officejet Pro 8600 Plus e-All-in-One -...
How do i set the number of rings re answering
Follow these steps to change the answer ring pattern. Press the Setup button on the product control panel. Press the Right Arrow button to select Advanced Fax Setup , and then press the OK button. Press the Right Arrow button to select Distinctive Ring , and then press the OK button. Press the Right Arrow button to select one of the following options: All Rings Single Rings Double Rings Triple Rings Double & Triple Rings Press the OK button to select the option. Press the Back button to return to the main menu.
Jul 26, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Black inkcartridge doesn't show
Since your printer is new, is should be covered under guarantee. Please take it back to your dealer, he should swop it out. Alternatively you can arrange a replacement from Lexmark direct through their website.
Feb 28, 2010 | Lexmark X6675 Pro Colour Wireless...
My cyan ink won't print. i have tried EVERYTHING.
The printer cannot use photo inks like Photo Cyan or Photo Magenta. Be sure to use "BCI-6 Cyan" in position 5 - farthest to the right.
Nov 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
ERROR6502
Error 6502 is a ink tank position error, one of the contacts for the ink tank in the carriage could be bad, or simply a wrong cartridge installed. You can't use photo magenta in a magenta slot, or photo cyan in a cyan slot.
Jul 15, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
My Xerox 8550 has Printer Error: 09,035.43
That is an issue with the cyan ( blue ) ink stick not loading properly.
What has happened is one of the blue sticks had stuck and not advanced properly or otherwise is not making contact with the loader switch .
One of cyan sticks may be broken, or cracked, twisted in the loader or even the wrong stick and not shaped the same on the bottom side.
Take about a 2 or 3 inch drywall type screw and twist it into the cyan blocks and slide them back if you need to remove and reseat them. But that is your issue. One of the cyan blocks is not moving into proper position.
Jul 15, 2008 | Xerox Office Equipment & Supplies
Need to change ring on fax to 3 rings. it is an hp office-jet 6110 all in one
  1. Press Menu .
  2. Press the right arrow (>) or the left arrow (<) until Advanced Fax Setup displays.
  3. Press Enter .
  4. Press the right arrow (>) or the left arrow (<) until Answer Ring Pattern displays.
  5. Press Enter
  6. Press the right arrow (>) or the left arrow (<) until the desired ring pattern displays.
    • Single rings – The fax machine answers after a single ring.
    • Double rings – The fax machine answers after a double ring.
    • Triple rings – The fax machine answers after a triple ring.
    • Double and triple – The fax machine answers after a double and triple ring.
    • All rings – The fax machine answers any ring. This is the default when not using Distinctive Ring.
  7. Press Enter .
May 09, 2008 | Office Equipment & Supplies
Printer Error
I fixed this problem by installing a new magenta ink cartrige. This makes me believe the problem is in the replacement cartridges. Of course this is not very satisfying because I had to discard a 3/4 full ink cartridge.
Oct 16, 2007 | Canon Pixma MP800 All-In-One InkJet...
Kingston 256MB printer memory for HP Color LaserJet CP1518ni Printer Logo
250 people viewed this question
Top Kingston Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Kingston Office Equipment and Supply Expert? Answer questions, earn points and help others
