Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Model GW609NZ f&p washing machine/smart drive 6.5kg excellence
Washing machine starts but stops with flasing lights,error code 43 was worked out,what could be the problem,happened before but cleared itself
  • Anonymous Aug 13, 2008
    washing machine wont go, not even light up on switching on of power.did a wash complete but machine gave off a smell of something over heating Did a scud cleanse as advised but machine stopped dead with a wee thud sound then terrible smell. turned off to cool upon restarting a day later got spark from pump area then nothing since.
  • 639 Answers
Dear herman worth and Guest also!,
ngfam1 here for you!
I am happy to be of assistance!
FIX IT NOW BEFORE IT GETS WORSE AND COST MORE!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Pleas egive me a good rating here in fixya.com before you sign out!
Posted on Aug 26, 2008
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
I have a Fisher and Paykel GW708U Smart Drive Excellence 7.5kg Washing Machine. What is fault code 43?
43. (00101011) Phase 1 to 6 - OOB Switch Fault
The Motor Controller module has found that the signal returning from the out of
balance switch indicates that the switch is permanently on or the harness to it is
disconnected.
Primary Source: Mechanical.
Action:
1) Check that the out of balance switch is free to move.
2) Check that no harnesses are blocking switch movement.
3) Check that the switch operates correctly when activated. Replace the switch
if suspect.
4) If the out of balance micro switch shows signs of corrosion, replace the
switch and switch harness, and fit a condensation kit to the console area if
not incorporated in the top deck.
5) Check the level of the machine and also the bias spring.
Secondary Source: Wiring.
Action:
Check the harness to the switch is connected correctly. The terminals should be
connected to the normally closed position. If the harness terminals show signs of
corrosion, then fit a new harness.
Jun 18, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
My fisher & paykel smart drive excellence 7.5 washing machine squirts water in a few times and then stops and beeps and displays 3 lights red orange and (short wash) green as well as low and med speed...
Although slightly unclear these are the only possible error combinations for the leds on the machine as you look at it with red always on the end right hand side.
(11) 1011 (Green - nil - Orange - Red) - pressure problems perhaps a blockage in the tube to bowl.
(13) 1101 (Green-Orange-nil-Red) - pump is faulty
(15) 1111 (all lights on) - display module is faulty
I do not recall that the leds across the spin speed actually means something.
Good luck
Jun 06, 2011 | Fisher and Paykel Washing Machines
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
Fp excellence 7.5kg starts filling then stops, tries again a few times shorter each time and then errors with following led pattern: 00101011. We have levelled and tried over and over again, very...
Fault code 43
OOB switch error (out of balance)
CHeck Bowl Is Balanced Check Bias Spring is keeing bowl central
Most Likely Cause Corred terminals on Out Of balnce micro-switch
Jan 01, 2011 | Fisher and Paykel (IWL12)
Code 43
Error Code 43 means OUT OF BALANCE SWITCH FAULT.Is your model an ECO smart model?Have you or can you borrow an electrical test meter to test the OUT OF BALANCE SWITCH?Please reply with additional information and I am sure I can help you rectify this fault.
Jul 22, 2010 | Fisher and Paykel WL37T26DW1 Top Load...
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Washing Machines Logo
812 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
