Question about Leviton 5613-2WSP Grounded Switch
I replaced a three-way toggle switch, wiring it exactly the way it was and now it doesn't work. It has two upper brass screws on the side as well as two lower black screws. Also a green screw that I thought was the ground. Since there was no ground wire attached to the broken switch, I didn't worry about having one attached to the new switch. Also, the old switch was a 15 amp and the new one 20 amp, but I didn't think that would make a difference since I was going bigger instead of smaller. Arg. Help?
You installed a 4-way switch as evidenced by 2 dark screws and 2 brass screws.
3-way switch has 2 brass and 1 dark.
Ground wire is not required.
Posted on Mar 29, 2011
I am trying to install a double pole pass and seymour toggle switch to electric outdoors for a pool pump and pool timer. this switch appears to match the old one so I tried to wire it exactly the same. All...
Hi Jeremy,
You need a double pole or S2 switch rated at least for 240V / 20A.
It sounds like you're describingt a four way switch or S4. A quick check of the handle (if the traditional toggle type) can help you identify the switch; it should have "ON" and "OFF" indicated on it if it is an S2 and nothing at all if an S4. S4 switches almost always have four brass or gold colored screws while S2 switches nearly never have four brass or gold colored screws (not counting the green ground screw - of course).
One or more S4 switches are used between three way or S3 switches when 3, 4, 10, 20 or more switches are needed to control lights or other devices (typical usage to turn lights on and off at each floor to a stairway in multi-level buildings. These are typically 120 volt residential circuits in the U.S..
S2 switches are required when controlling two hot wire circuits that need both hot wires to be opened when shut off. These are typically 240 volt residential circuits in the U.S..
I hope this helps & good luck!
Apr 15, 2012 | Electrical Supplies
We have a leviton toggle switch that has one black screw and two brass screws....which one does the black wire go to?
You have a three way switch in your hand ... which is used in conjunction with a second three way switch. The two black screws are called the travelers (and are connectedd together). The brass screw on switch #1 gets load (work) and the brass screws on #2 gets line (power).
If you are only turning a light on at one location, you need a single pole switch. Basically, you break the black wire with the switch.
If you need more assistance than this, post a comment.
Thanks for your interest in FixYa.com
Jul 28, 2011 | Leviton 15a 120v Sp Switch
Have switch 691-WCC6. Replacing an old outlet with no ground wire - have 2 black and 2 white wires coming out of box. Looks like two brass connections on one side and silver one on the other side with a...
Question is posted under switch, but asks about outlet.
Outlet is where you plug extension cord for example.
Usually screws are color-coded.
Outlets have brass and silver screws.
Without testing wires, trying hooking wires to same color screw they came from.
If breaker blows, then take off one wire and try again, or test wires to see what each is connected to.
As general rule with newer wiring inside outlet box, code says Black wires are Hot and go to brass screws, White wires are neutral and go to silver screws.
Older wiring could be very different especially if wiring was not done by code.
Use cheap circuit analyzer from home center to help diagnose outlet problems.
Add a comment with photo of your old wiring device, plus wiring.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Apr 10, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
I have a Leviton single pole rocker switch grnd, pilot light back and side wired #5628-2W i am trying to hook it up so light is on when switch is on i have 2 black wires 2 white wires and 1 ground wire how...
easy one first: ground wire to green screw. We have to assume the two black wires are the hot(coming from power source) and switch leg(going to light). Switch will have two brass colored screws. Looking at the switch with the off/on markings right side up. Put hot wire on upper screw and switch leg on other brass screw, With nothing hooked up, the hot wire will be the only wire with voltage on it. You can buy a non-contact voltage tester at Lowes or any place that sells electrical supplies. Now we must assume the two white wires are neutrals(one coming from power source and one going to light. The pilot light part of the switch will either have a silver colored screw or a white pigtail on it. all whites hook together. The pilot light is wired internally to the switch leg. Your switch should work properly now.
Jan 28, 2011 | Leviton COMBINATION SINGLE POLE TOGGLE...
I have a new combination switch ; I want to control two lamps from one switch i connected the main lines the white one from brass upper and the other from black screw and went I turn on the switch the...
The white wires from the two light fixtures get connected to the white wire from your power supply.
Then the black from your power supply goes to the gold colored screw on the switch. Lastly, the two black wires going to your light fixtures get twisted together with a third jumper wire. The other end of the jumper goes on the silver screw on the new switch.
Dec 21, 2010 | Leviton 15a 120v Sp Switch
I am trying to replace a 1 toggle switch along with a receptacle with a 2 toggle switch. The present toggle switch controls an outside light. I am planning to put a small hard waired light on the inside...
I specialize in wiring devices and timers.
You are adding a new light.
You need to wire a switch to the new light.
The existing box has a switch and receptacle.
Here's where I am confused:
I am uncertain if the original switch and receptacle are a single device.
Of if you have separate switch and separate receptacle?
And then:
What kind of device are you adding, a single switch?
Are you replacing the receptacle with a switch?
Or are you installing a double switch as shown below?
Add a comment and tell me the devices you are working with and the color of the screws on sides of each devices and I will get it wired correctly for you.
The double toggle switch shown above has brass screws on one side and silver screws on the other side.
The brass screws are connected by a brass plate.
The silver screws on the other side of the device are separate.
The hot wire connects to the brass screw.
The outdoor light connects to one of the silver screws.
The new light connects to the other silver screw.
Nov 06, 2010 | Pass & Seymour #690WGCC6 15A White 2SP UL...
Dual receptacles (hot all the time) next to dual rocker switches. One switch controls a light, the other a disposal. I've got three black and one white wire ( ground). The post set up on the rockers...
What are you doing? I can't figure it out.
I think you have a new double rocker switch and you are trying to replace a double toggle switch and you don't know which side to put your wires?
The screws are color coded. Look at the screw colors on old and new switches and follow same pattern.
If this is incorrect, answer back and I will help.
If you are adding another circuit.
That means running a new wire into the box to power another receptacle box, or to switch another light fixture.
If this is the case, the best place to connect any new circuit is the existing receptacle.
Connect new black wire to brass colored screw
Connect new white wire to silver colored screw.
Oct 25, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
I need a diagram for home wiring, 2 gang switch and a 3 way switch.
A two gang switch will be a swith witho the the shape of a duplex outlet. with a toggle on each end. there will be two screws on each side with possibly a green screw on one of the sides. The green screw is for ground, and should be either attached to the box or a green wire all the way back to the panel. The screws on one side will be a copper brown color and you will notice a strip of metal that connects the two screws together. This is the hot or common side (usually a black wire. The two screws on the other side will be a bright copper color, and they will be the swich leads from the switch to the fixture you are attempting to power up (the wires that connect to these switch leads are probably any color but green or white). Never connect the neutral (white) wire to any part of the switch.
The three way switch will have three screws on it. One is copper brown, and the other two are bright brass in color. The dark screw is the common (black wire). the other two screws connect the runners from one switch to the other switch. The runners dont connect to anything but the other switch. On one end the common wire attaches from the switch to the power and on the other end the common wire attaches from the switch to the fixture. The white (neutral) wire does not connect to the switches, it runs from the panel directly to the fixture.
I hope this has been helpful.
Mar 25, 2010 | Gb Electrical GSW-117 Toggle Switch
I am replacing a double switch which controlled separately a bathroomm fan and a light which to use
One side of the switch has Brass screws, and the other has nickle screws. there is usually a small brass bridge between the upper, and lower switch screws on the brass screw side. if you are feeding both from a common power source leave the little brass bridge in place, and screw on of the screws in all the way. Put the energised wire under the other brass screw. Bare copper wire goes to the green screw. The power will be transferred to the nickle screws through the corresponding switch. put the wire to the fan on one, and the light on the other. Presto.
Aug 14, 2009 | Leviton Electrical Supplies
3 ways not wired correctly
Im not sure if you know what you got yourself into but i hope this helps. Sorry for all the words but this does take some reading if this is new to you.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Dec 13, 2008 | Electrical Supplies
Leviton 5613-2WSP Grounded Switch Logo
69 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
Gene Haynes
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
