Question about Dell PIII 733Mhz/ 256KB,133, S1, for PowerEdge 2450 (SL3SB) DEL733-SL3SB-06 (DEL733SL3SB06)
Dell PowerEdge 2450 was frozen. I had to turn it off. When I restarted, it could not detect the hard drives. It will not boot to operating system
  • 120 Answers
GET TOUCH WITH DELL TOLL FREE NUMBER 1800 444 026
Posted on May 26, 2011
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
My Dell Dimension 2400 refuses to load Windows XP
What happens?Does it hang on the loading page or does it restart itself before loading?
If it hangs on the loading page,press CTRL,ALT and DEL.This boots the system.
If it restarts itself,remove the hard disk and re-fix it again.Problem solved?
Remove the CMOS battery and the hard disk and re-fix them again.Problem solved?
If not,you may have to repair your operating system.
This how you do it:-
  • Remove your hard disk and enslave[fix it as a secondary drive] it on another machine with a good operating system.
  • Start the machine.Accept to run unnix[using two drives]
  • The machine will automatically detect your hard disk's failure on the operating system and repair the damaged files.
  • On completion and after Windows opens,turn off the machine and remove your hard disk.
  • Fix the hard disk now on your machine and start it.
Hope this helps.Thanks!
Please rate this answer.
Oct 31, 2011 | Dell Dimension 2400 PC Desktop
Dell PowerEdge R710 Installation error I have the same problem while installing Windows Server 2003 installation process reach to the step asking press F8, when pressing F8 it says no Hard Drive were...
ok you will need to get the windows 2003 drivers for your raid controller and put them on a floppy disk. when you first boot off the cd you will see a prompt to press f6 if you need to install any additional drivers. insert the floppy disk and select which driver you wish to load.
you should be able to see the hard drives now to partition/format.
Mar 09, 2011 | Dell PowerEdge R710 Server (D263K)
DEll Poweredge 2450 no chassis key
On the face plate where the key plate is numbers, most college will have the key . I open them quite often with a paper clip and small blade screw driver
Or remove the pins on the hingeside of the face plate if this is the U2 platform
If you not find any help send me the numbers for the key needed and I will see if I can find the key you require.
Thes locks are not too secure and from all the 2450 and 2400 even 2550 I work on only 4 keys total
Nov 20, 2009 | Dell PowerEdge 2450 Server
Dell server cont detect hard disk
chk for boot sequence in the BIOS and chk the hard disk is detecting in the BIOS
Oct 29, 2009 | Dell PowerEdge 1800 Server
Dell PowerEdge 2450 Server issues
FIrstly reseat all removable components in the system and retry
Second remove all DIMMS except one. try again
I not then remove this DIMM and put in another one. This is to test for a faulty DIMM thats hanging the POST
TRy these things and see if you get further
Mark
Aug 18, 2009 | Dell PowerEdge 2450 Server
Dell PowerEdge 1400SC Can not locate hard drives or partition
The controller (probably a RAID controller) that the drives are connected to is one for which Windows does not have the correct drivers. You need to supply the proper driver and .INF files during the initial load. The process used depends on the version of Windows you are installing.
Feb 19, 2009 | Dell PowerEdge 1400...
Boot problem
If its not detecting the hard drive maybe you have a loose cable connection
Oct 28, 2008 | Dell USB&Audio I/O Front Panel J0016
Will not boot up
hi there, check the cmost setup for hard drive detection. if detected you may have a software prob., try to re-install your operating system, i.e. windows, hope you can save your documents files before you can install new operating system. ty
Feb 18, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Open Questions:
Steps To Fix Toshiba Laptop virus and Freezes Issue Call toll free Number :+1888784-9316 Are you facing sudden pop-ups on your computer or witnessing slow loading of files and programs? If you are getting issues like slow internet and processing, unexpected computer behavior then contact Toshiba support for making your computer free from all such dangerous online threats. Toshiba support provides safe and secure removal of all virus and other infections along with protecting the system from any such instances further. Toshiba support providing technicians make sure that your pc is secure and also that all your important files and documents are safe from any type of harm. If your system is infected with viruses, Trojans or malware then it might show signs like slow computer processing and internet speed, unexpected computer behavior, sudden freezing and crashing down of the system, frequent arrival of error messages, many advertisement pop-ups, non-intended outgoing emails and messages to contacts, files disappearing, problems in hardware and accessory devices, screen freezing and image blurring issue etc. Toshiba support helps in scanning all the variants of virus inhibiting the system by using proper scanning process and removal processes after that. Many a times, user while scanning viruses on his system might not be able to remove all even after many attempts. This happens because system gets infected to new variant of virus due to vulnerabilities of programs used in that system or because of inefficient scanning methods. The anti-virus program used for scanning the presence of that virus might not have got that virus's signature. So, for proper and efficient scanning of all viruses and removal afterwards, it is necessary to take help from experts like Toshiba support technicians. These technicians utilize the efficiency of advanced techniques and much better tools to clean the system and make it infection proof in order to yield greater productivity. Specialists of Toshiba support collect samples of all the variants of new and recent viruses and update the user's software database with their signatures. In case your system is also suffering from the infection of any such viruses which is new and is creating trouble getting detected, then contact Toshiba support us for help on their toll-free Toshiba customer helpline number +1888784-9316 anytime for expert supervision and advice.
Aug 14, 2018 | Toshiba Computers & Internet
See all Dell PIII 733Mhz/ 256KB,133, S1, for PowerEdge Questions
Computers & Internet Logo
49 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
