Question about Technics SA-DX930 Receiver
Right speaker does not work on both A and B - Technics SA-DX930 Receiver
    Sergeant:
  • 298 Answers
Before doing anything else swap the speaker connections over to make sure that the problem is in the amp and not the speaker / speaker cable.
If that doesn't solve it then it is most likely an internal fuse blown on the amplifier circuit board - they are little tiny glass ones, obtainable from most tv repair shops, but it is important to get the right power rating. Also some of these fuses are 'quick blow' (go instantly there is a fault) others are 'slow' or 'time' blow - take a second or two before they actually blow - make sure you get the right one (timed usually have the letter T next to the power rating)
Posted on Mar 23, 2011
Need help with altec lansing ada 745 4.1 speakers
Does the right front speaker need to work in order for the whole speaker system to work?
The whole system can still work with or without it.
Here is an additional tip how to ..... Computer Speakers
Sep 29, 2012 | Altec Lansing ADA745 4 Speakers
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
RIght speaker not working in speaker system. Switching the left with right speaker make the right speaker work (not speaker) Plugging the 2 RCA into a different input changes nothing. 2 rear speakers...
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Jan 17, 2011 | JVC Audio Players & Recorders
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
One speaker wont work
if u have experience with the soldering of the terminals then you can open the speaker casing of the sub woofer and then solder the right speaker input wire.
dont do this if you have no previous experience and DISCONNECT THE POWER SUPPLY before doing any work inside.
Apr 19, 2009 | Logitech Z-2300 2.1 Computer Speaker...
I have an nokia n78 and my right speaker isnt working
hallo i have N78 its right speaker not work now its dont work at that time when i play song at that time i masg i reseve that at that time right speaker not works plzzzzzzzzzzzzzzz answer me
Feb 19, 2009 | Nokia N78 Smartphone
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
Speaker Problems
Can you swap speakers and see if the left working speaker works when plugged into the right output?
If it does, then your right speaker is bad or the right speaker cable/plug may be bad.
If the working left speaker doesn't work on the right output, then I would suspect a problem in the right channel audio amplifier.
Please let me know if I can be of further assistance to you.
- Jim
Feb 29, 2008 | Emerson MS3100 3-Disc CD Changer
My right control speaker doesn't work.
your speaker control cable is not working right try to push the cable in to the speaker a litte bit and then try.
May 13, 2007 | Harman Kardon HK595 Computer Speakers
Technics SA-DX930 Receiver Logo
97 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
