Question about Zanussi Washing Machines
Lock symbol on time display and machine will not work how to reset please
Reset lock key
it probably got stuck. to reset you must unplug it or press the
reset button for lock key... there should be a button of lock...
lock some button or just unplug it and wait some seconds.
Jan 21, 2015 | Washing Machines
Lock displaying symbol
Haven't done this exact model but usually it means keypad locked (child lock) should be in the manual how to unlock. Usually hold down a couple of buttons for 5sec.( most of the time a faint lock symbol will be written between the buttons on the button panel.)
Sep 23, 2013 | General Electric WCVH6800J Front Load...
My washing machine is beeping and showing the key light and not turning on. The door opens though but it seems to be saying its locked!? It doesn't show the cycle time either. How can i get it to go...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch, but you didn't specify the model number. It sounds like the "child lock" selection has been activated, either intentional or accidental.
To reset it on many Bosch it is as follows...(if this fails, please provide your model number)
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
**Many times you can also push and hold the start key for several seconds and this too will deactivate the selection...on various models**
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for choosing FixYa. I'll need to watch for your reply if that doesn't work or before moving forward.
Regards,
Macmarkus :)
Aug 16, 2011 | Bosch Washing Machines
Bosch exxcell 7 washing machine (1400) Power cut at home. Display now shows key symbol - 12 minutes 1200 spin speed Have tried unplugging. Controls will not reset
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Jul 08, 2011 | Bosch Washing Machines
I have a bosch clasixx machine there is a symbol like a key on timer and machine wont start how do i get rid of this
Hello, Welcome to fixya.
The Key symbol means the lock has been activated some how.
Here`s how to deactivate it...
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Oct 20, 2010 | Bosch Washing Machines
Washing machine shows key on the display and won't start
Regards,
Macmarkus :)
Oct 20, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Lock Symbol staying on
On most bosch of your class this is how you work it on & off.
Thank you for visiting "fixya" for your washer solution inquiry.
macmarkus :)
Sep 03, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My Beko washing machine is displaying C on on the display and will not start.Any Ideas please.
"C on" means that the child lock is on; press the two buttons that are linked to a lock symbol at the same time for 3 sec. ;)
Sep 01, 2010 | Washing Machines
Bosch classixx 6 1200 express is showing a key symbol in the LED - when I switch on the washing time goes back to 0 and the alert sounds and I cant start the wash I dont know how to switch the key...
macmarkus :)
Aug 19, 2010 | Bosch Washing Machines
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
