The control board came loose underneath, and I don't know where to re-attach it. Is there pictures of where it goes.
  • 5 more comments
  • cjones692 Mar 22, 2011
    Frigidaire gltf2940ee0
    frigidaire gltf2940ee0
  • cjones692 Mar 23, 2011
    CONTROL BOARD
    Part Number: AP3891780 made by FRIGIDAIRE
    http://www.youserguide.com/wiki/Electrol... The parts I'm asking about is number 4 & 5 in the link I provided. The problem is that the drawing doesn't show where those parts are suppose to be attached at. The control board also has a green wire coming from it that needs to be attached somewhere also. The green wire is probably a ground wire.
    President:
  • 1,654 Answers
What is the make and model of your machine? it is not listed.
Posted on Mar 23, 2011
  • 1 more comment
  • Dcramer531
    Dcramer531 Mar 23, 2011
    www.manualsonline.com/ex/thread/view/idThread/857698 Here is a link to a manual with exploded vies of the fridgidair washer. I don't think the model is the same but you will get an idea of what goes where. When the link opens look below where it says comments. you will see a green link to the manual. It is free
  • Dcramer531
    Yes that is what I saw also in the diagram in the link I sent you also, 4 is the control speed and 5 is the box control. they should mount to the bottom of the cabinet, yes I believe green is the cabinet ground or neutral. On page 8 of the diagram in the link I supplied show the wiring diagram.
  • Dcramer531
    *I looked at your diagram closer and 5 is the mounting bracket for the controler. 5 on mine was box control, sorry if I meeded you up.
  • 4,070 Answers
You can post your model number at THIS SITE and find diagrams of your washer or post the number back here and I'll look for you.
Posted on Mar 22, 2011
  • Charles T Nevin
    Charles T Nevin Mar 22, 2011
    Here are your diagrams. Just pick the part of the washer you need to see.
Hi Don: I don't know how to reply to our original conversation, I'm not seeing a reply button on the original post.
Hi. Go to fixya.com and somewhere underneath my response you will see a button marked "HELPFUL". Just to the right of that button you will see another icon named "Comment." Press on that and you can reply directly there. You can paste pictures there as well.
Nov 27, 2017 | Cameras
I have a panasonic th42px60u my problem is that none of the controls work except the on and off volume is on but unable to increase or decrease the volume. What part do I need to buy to fix the problem,...
Good day Mr.Daniel Navarro..
The picture below is the sample 42" plasma TV (internal parts)..
If your TV won't adjust volume or change channel by pressing button on the front panel..The problem could be the digital control board,it is the one that have a rectangular red on the image shown..
But before you replace the board make it sure that the control button assembly is properly connected on the said digital control board ( no loose connection or loose solder)..
Also try this remedy:
If you have remote control you can use it for the mean time to adjust the volume and channel so that you don't need to replace the digital control board..
Hope it helps..
Thanks for using fixya and purchased my service..Please don't forget to rate my answer..
Nov 23, 2011 | Panasonic Televison & Video
I have power at the connection underneath but nothing works on the control panel no lights no anything and it doesent run
Incoming power goes through the door switch first,then to the control panel.
Your door switch attached to the door latch may be defective.
If the door switch checks good on a meter then the control board is bad.
Mar 06, 2011 | Maytag 24 in. MDB6600A Jetclean II...
Error code 20 will not drain water and don,t know how to open washer to check drain
What is your tecnical ability? According to the manual, it could be faulty wiring between the pump pressure switch and the control board. If the connections are corroded, or loose correct the wiring. If the wiring is good replace the pressure switch. If that doesn't work then control board needs replaced.
Let me know
Jan 09, 2011 | Frigidaire Affinity ATF7000E Front Load...
I don not know which end goes where and explain whit a picture showing which end goes where
here is a link to your manual, which has lots of pictures. If this doesnt do it for you please give me more specifics as to which ends you are trying attach and i can be of more assistance.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3192753&cc=us&lc=en&dlc=en&product=3192753
Sep 06, 2009 | HP Photosmart C4280 Aio Printer
Sanyo LCD TV DP32746 no picture
Easy way to Diagnose is get a known good CCFL from a laptop or LCD TV and start plugging it in to the existing Cathode's Ports one at a time. Generally its a bad CCFL on these multiple units.. (2,4,6) Bulbs.. Moniserv.com for replacements.
Goodluck guys!
Mar 17, 2008 | Sanyo DP32746 32 in. LCD Television
Picture Flashes off and on
probably the tv has a loose solder in the board. this is normal especially when tv is aging. most of the components inside are emitting heat resulting to loose the solder. try to inspect and resolder if possible. but if you dont have the proper tools and equipment and you're not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Jan 31, 2007 | Sony KV-32S45 32" TV
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
