Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
In the middle of screen the is red area next to the bottome of the picture,and also the picture is not bight like it used to be seems like everything is darker.
  • 84 Answers
Bad optical engine. Your repair cost will exceed $1200 since this part is so expensive. Part# UX25302
Bill W
integrityhomeworx.com
Posted on Mar 23, 2011
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
RCA D52W23 breakdown in projection focus
First check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v If cp150 is puffed up on top it is bad , then there is a fuse FL231 on right side of flyback transfomer it will be the middle fuse if open you will lose convergence on picture .
Dec 30, 2008 | RCA D61W20 61" Rear Projection Television
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Warping
If this is a projection tv then replace convergence amps. and resistors in the area also look for open fuses.
Sep 05, 2007 | Philips 55PP9352 55" Projection Television
Good picture in the middle but picture gets worse going to top or bottom.
The convergence IC's need to be replaced. they are the black standup IC's standing up and mounted on a metal heatsink. They are soldered into place and this set is a solid state set and have no user replaceable parts unless you have the training to solder and trouble shoot electronics. You should call a pro in to assist you with this repair.
Sep 27, 2006 | Sony KP-53V45 53" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
