Question about Vizio VW37L 37 in. LCD HDTV
I am plugging in a cable from the dishnet satellite in to the antenna port in back and i can't get it to work. But my other tv's work fine doing the same thing
  • 902 Answers
You usually cant go directly from the dishnet sat antenna to the tv without convert (dish box) i would try put it in the cable port and run from the menu options channel scan. do tht as well with the antenna port.
Posted on Mar 22, 2011
I have a 65" Mitsubishi dlp tv. Now when I connect anything (cable box, blue ray, ps3) to my 3 Hdmi ports the screen will flash like it is trying to receive signal. The picture will show then go away over...
make this test and fix it. God bless you
  1. Verify TV is plugged-in and getting power.
  2. Verify your home's power breaker has not tripped.
  3. Verify the batteries in the remote control are good.
  4. Verify you have selected the right input for Cable/Satellite, antenna, DVD, VCR or Game Console.
  5. Verify the cable/satellite box is plugged in and getting power
  6. Verify you are getting cable/satellite in other parts of the house
  7. Verify the VCR is plugged-in,getting power, and turned on.
  8. Verify that all wires are connected to proper place
  9. Scroll through input screen to verify you are watching the correct inputs
  10. Look at the FAQ on the manufacture's website or user manual
The Basics
Before we explore more complex tv troubleshooting techniques, we need to examine the basics. First, we need to verify the TV is securely plugged into a power outlet. Don't laugh, but failure to plug-in the TV is the number one reason reported why electronics do not work. Second, you need to verify the remote has fresh batteries. This can easily be overlooked. The remote can be working one minute and not working the next, so replace the batteries Finally, verify that all cables and connections are correctly and securely attached.
Nov 04, 2013 | Televison & Video
Which end is the receiving end of a house tv areial
peter_321
One end of the coax cable is connected to your antenna. The other end connects to a coax port on the back of the receiver labeled "TV/Antenna Cable In". All DISH Network receivers have this port on the back except our "K" series receivers. These receivers require a module to plug into the back of the receiver. Connect the antenna cable to this port, "TV/Antenna Cable In", if the receiver has the port available. I hope this helps.
Ray Calo
DISH Network
Mar 05, 2011 | Televison & Video
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
Switching from Comcast to Dish Net and back again
Press the unput button and select the location.
Feb 25, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Sep 18, 2008 | DISH Network Televison & Video
Connecting to Direct TV satellite box
If the cable is connected to Antenna/cable port on your TV, then set the TV to antenna mode and search for programs after which you should have some stations showing.
Jan 16, 2018 | Sanyo DS24425 24" TV
Vizio VW37L 37 in. LCD HDTV Logo
97 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
