Question about Amcor Heating & Cooling
I purchased an Amcoraire split system unit for my 2 story garage. Licensced electrician did the wiring and licensed HVAC co. installed the 2 indoor units and outside unit. Outdoor unit is Model # AOM 243 HX 24000 BTU Indoor units are both Model #AWM123 HX, 12000 BTU each When I turn the unit on, it runs for about 60 seconds and then I get an error code on the inside wall unit that says P7. My manual says this has something to do with voltage. I had the power company come out and they show the voltage range to be with-in their limits at about 248. I can't ever get through to the Amcor phone support and my HVAC guy is out of ideas. Help
    President:
  • 2,047 Answers
Since the manual says the error code has something to do with voltage it means the voltage is either too high or too low. And as the electric company says the voltage is within limits the the error is as a result of the voltage fluctuating. All you have to do is get a voltage regulator about 5000watts each for the units and the error problems should cease.
Hope this solution has been helpful?
Posted on Mar 22, 2011
E 7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2), Check loose wiring/condenser coil for clean
Jan 10, 2011 | AmcorAire UCHW-H24AF2 Split System Air...
E7 error message
The E-7 error code means the 2 wire defrost cable between the outdoor & indoor unit is disconnected or broken
Sep 10, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
We purchased a Amcor Amcoraire Mini Split Unit ? 12000BTU However the Power Transformer Input: AC115-120v 60hz Output: 10.5v 550mA isn't working as per the installer and we can't seem to find it...
Hi, this is a 1-ton cooling unit per your numbers. If they just installed it and the line side (120 volts) is good but nothing on the secondary low voltage side, they should have replaced the transformer themselves? If it is a split system, it is normally on all splits to be located in the indoor unit control section. I can't tell you exactly, but look where the 120 volts come into the indoor unit and the high voltage wiring should be connected to it then stepped down to lower voltage. It may have a fuse on the circuit board that they blew when installing it. If you are not familar with electrical, I wouldn't attempt to make these repairs. You can look for a small plug in type fuse to see if it blew, it looks like one on your automobile. I would call this installer out and its there job to do this!! These transformers look different, there not all the same, but will have a black and white wire coming in, and several colored wires coming out for low voltage. It will be in the indoor unit. Keep me posted on what you find or if you need more help. How long ago was the unit installed?
Shastalaker7
Jun 15, 2010 | Amcor AF 12000E Portable Air Conditioner
Air circulator not working on unit
We stock a complete line of replacement parts for Amcoraire Mini Splt Systems.
Support@Pridiom.com
201-266-8234 option2
May 28, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Hello im trying to trouble shoot two split systems the electrical wires were crossed for the two units I fixed it the compressors wont come on, wall unit says e7? This is on the Amcoraire ac split systems.
E7 indicates an "External Feedback Problem" which sounds like a communication problem. I believe there is a sensor cable that runs from the outdoor unit to the indoor unit also. Check that all cables are properly run to the appropriate unit and check all connections for tightness. Here is the link to a manual that includes installation and wiring instructions.
http://www.acwholesalers.com/EasyEditor/assets/amcor%20duo%20uchw-h12%20owners%20manual.pdf
Mar 16, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Blower fan runs at one speed - very low
There is a sensor on the indoor coil that needs to reach a certain temp before the fan speed will increase. Sounds like the unit is undercharged if the sensor isn't reaching the temp it needs to.
Mar 09, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
Heating & Cooling Logo
59 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
