Question about Toshiba Satellite A135-S4527 Notebook
TOSHIBA SATELLITE A 305 IS NOT GETTING POWERED ON AFTER PUTTING ON CHARGING FOR NIGHT. THE ADAPTER IS WORKING BUT LAPTOP IS NOT GETTING ON PLEASE HELP
  • 384 Answers
Hi There and Welcome to FixYa!
It's really not ideal to "overcharge" your laptop computer as this would result to this problem that you're having right now. The primary step that you should try, having determined that the AC adapter works, is to :
  • Unplug everything from your laptop, including the power cord along with all USB connections.
  • Carefully remove the battery of your computer.
  • Press and hold on the "Power" button for about 10 seconds.
  • Connect the AC power on your laptop (without the battery) and try to turn it on.
  • If successful, do the same thing with the battery attached this time.
This would help you zero down on the cause of the problem if it's the battery, ac adapter or the computer's motherboard. I am highly recommending for you to contact Toshiba's technical support if the above steps did not help you at all :
Toshiba Support
Thank you for using FixYa.
Posted on Mar 22, 2011
Toshiba battery charger pa3468u-1aca for satellite L305-s5944 is beeping and the unit is not charging, what is wrong?
Probably a failed AC adapter. Please try to charge the laptop with a good, working AC adapter & see if the problem disappears.
Jun 12, 2011 | Toshiba LAPTOP AC Adapter Power Charger...
My Toshiba satelllite A 305-S6905 System unit laptop just stopped charging , it does not switch on. only yesterday, it was working fine with no problems. it is just two years old .
Please check your battery for right voltage. if the voltage is down check the voltage in your adapter. If there is no voltage in the adapter then you might have to open check the continuity of the cord, normally this cord shorts and the adapter cutts off supply due to a high current error. So if there is shor tremove or other wise check the SMPS circuit for failed components, fuse, recifier, capacitor, driver. However if adapter works there must be supply at the battery terminal of the laptop, if not you have a failure in the charging circuit in the laptop. Hope you check this out one by one. Hope I could help. Good day
Aug 14, 2010 | Toshiba Satellite A135-S4527 Notebook
Suddenly my Toshiba Satellite A205 laptop died. No power.
First, check your power supply (the adapter). Is it putting out the required voltage to charge the battery?
If not, then you might have a dead battery and no way to charge it.
If the power supply is working and when you turn on the computer you get no lights, then you're probably looking at a new motherboard.
If you get startup lights and hear the fan, then it's getting power and you might have a video problem. But it sounds like, from what you wrote, there is no activity at all when you try to start it. That would be the power circuit on the motherboard, most likely.
Jan 09, 2010 | Toshiba Satellite A205-S4617 Notebook
There is power in the laptop.
if you say that either the battery nor the adapter was tested and seemed working fine but not actually giving power to the laptop itself then the problem is the motherboard from your laptop i m afraid
sorry i have no idea about the service center in tamilnadu
Feb 04, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite M45 S331 PSM40U-01R001 will not power on
No.. the problem has nothing to do with your battery....
Yes Quite Possibly the motherboard is fried...
Nov 18, 2008 | Toshiba Satellite M45-S331 Notebook
Toshiba laptop not getting power
To g_mart
Its sounds like either your power cord is fried, or you need to replace the power jack in your laptop. Unfortunatly, this is a common problem for toshiba's.
Oct 23, 2008 | Toshiba Satellite Pro 490CDT Notebook
Toshiba Satellite A65-S1064 Need help Please
you can do power cycle on the laptop. turn off the comptuer. unplug the ac adapter and remove the battery pack. press and hold the power button for 10 secs to drain all excess power on the computer. put in back the battery and ac adapter. if it doesn't help, do recovery. if your computer is overheating, visit one of the service centers of toshiba to check the cooling module and system board. just make sure that you're still under warranty because if not then you're gonna be charged for the diagnosis and repair of the laptop.
i hope this info helps you.
Sep 09, 2008 | Toshiba Satellite A65-S1065 Notebook
Toshiba Satellite A105-S4064; can't get battery to charge
If you put strain on the jack (e.g. hang power adaptor from it whilst using or charging) then the socket on the mainboard can get hot due to poor contact and melt.
There is no way to fix this except to completely dismantle the laptop and fit a new socket - most likely a repair centre will charge you for a new mainboard.
Try another adaptor to see if that is the problem (broken wire in cord) - otherwise look closely at the socket in the notebook.
Aug 08, 2008 | Toshiba Satellite A105 Notebook
My Toshiba Satellite battery is not getting charged. It worked previously, all of a sudden it stopped charging.
* check the wall power outlet is proper wheather power is coming or not if not change the outlet with good one if fine then
* check the power adapter is working fine (red light is coming when attached to power outlet or not,connected properly to the usb of laptop or not)
* if adapter is overheating or heating quickly change the adapter
*call for toshiba 1-800-457-7777
Jun 19, 2008 | Toshiba Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
219 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
