Question about HP CP3525DN Color LaserJet Printer
The printer used to automatically pull from tray 3 once tray 2 was empty - it's not doing that anymore so I have to press the OK button on the control panel!
  • HP Master
  • 1,915 Answers
Make sure that both tray 2 and 3 are set for the same size and paper type. This printer will not skip to the next tray if the paper is different. There is also a setting you can set for tray behviour which basically tells the printer to use selected tray exclusively or use whatever tray has the media that matches. HP printers will normally pull from the highest numbered tray that matches the paper type, so that your printer used to pull from 2 first and 3 second tells me that both trays are likley not configured for the same media.
Posted on Mar 22, 2011
How do I align the head on my Model-PIXMA MP 970 Canon Printer?
In short, while the printer is On, press the Home button on the printer, use the up-down button to scroll down the menu and locate "Settings", again scroll down and locate "Maintenance", press "Ok" and locate "Auto Head Align" and press "Ok", again press "yes" when you see a confirmation message on the screen. The alignment page will print out. Make sure there's paper in the tray (not in the adf) before performing this.
The long procedure is given below (if in case you need it):
Press and release the On/Off to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  1. Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  2. Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  3. Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 10, 2011 | Canon Office Equipment & Supplies
NO BLACK PRINTING on my Canon mx310 printer. in case of misprint please align head
Follow the steps below to align the printer
  1. Press and release the On/Off button located in the upper left-hand corner of the operations panel to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  2. 2 Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  3. 3 Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  4. 4 Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Regards,
Shawn
Feb 03, 2011 | Canon PIXMA MX310 All-In-One Printer
Default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Dec 09, 2009 | HP LaserJet 4200 Printer
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Aug 18, 2009 | Samsung CLP-610ND + Demo Laser Printer
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
"490: MP tray is empty" message when trying to print labels from Word 2003
The MP tray referred to is the Multi Purpose tray and is located at the front of the printer. To access it, you need to find the 2 indentations at the side of the front feed assembly and pull them towards you. this then gives access to the MP tray. Don't forget to press the blue button after loading the paper. Your user guide/manual will give clear instructions and pictures. It may also be called manual feed tray. Once loaded with the correct paper press the online button and printing will start.
Oct 18, 2008 | OKI C5500n Printer
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
HP CP3525DN Color LaserJet Printer Logo
267 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
