Question about Canon EOS-20D Digital Camera
The camera will not expose pictures properly; they are underexposed inside, or overexposed outside. The exposure adjustment feature is set in the middle or neutral mode. Changing the iso does not help. This occurs in all modes throughout the camera.
  • 52 Answers
It sounds like the light meter in the camera itself is probably broken and needs to be taken to a repair shop. Try using it in manual mode until you can get it fixed.
Posted on Mar 23, 2011
Shoot pictures of the moon best setting for that
Hi. I would recommend first you use a tripod or some stable support, second the best settings would be Aperture priority and use something in the region of f56-f8 or Manual and set f5.6-f8 and use the exposure indicator to adjust the shutter speed, use the spot meter function on the camera if you have it and vary the exposure by shooting at the recommended exposure and also by shooting overexposed and underexposed. Trial and error is really the only way to go.Set the ISO to 100 or 200 to get the best resolution as you will probably have to zoom it up to 200% on your computer screen to have a good image.
Apr 15, 2014 | Canon PowerShot SD1200 IS / Digital IXUS...
Camera exilim ex-s600 will not take pictures outside,pictures turning out white,yet will take pictures inside ok.is this a worthwhile repair
This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
Sep 10, 2011 | Casio EXILIM Card EX-S770 Digital Camera
Whenever I take photos in shutter priority mode, all the pictures seem to be UNDEREXPOSED not overexposed like most people say it is. It also says LO where the f-stop number should be. PLEASE HELP!
Your shutter speed is too fast. The correct exposure requires a lens aperture larger than physically possible on the lens. That's what the "LO" is telling you. Slow down the shutter speed until the "LO" goes away. Alternatively, increase the ISO sensitivity (or a combination of both).
Just because you can set the shutter speed to whatever you want doesn't mean you can get a properly exposed photo at that shutter speed. There may be too little light (as in your case) or too much light. You have to use a shutter speed appropriate for the subject and the light conditions.
Dec 20, 2010 | Nikon D3100 Digital Camera
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Over exposure
Hey - have the same problem. All my still pictures are coming out overexposed, no matter what setting I use. Tried resetting, tried new battery, tried new memory card, tried different exposure settings. Nothing fixed it or affected it. However, my movie exposure works great so I can take movies just fine. Are you able to take movies with no overexposure?
Jul 25, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Time for new flash??
the camera's light sensor or metering system, for correct flash exposure is no longer working, that's why your shots is either black or white (overexposed or underexposed) the flash firing has loose its control because of the defective sensor, it now only depends on the charge current of the flash capacitor. If you'll wait longer time the charge is maximum picture result will be overexposed(white), and vice versa, less charge, dark result, have the flash assy replaced. Daylight no problem, it doesnt use the flash circuitry, thanks
Jul 28, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Optio S40 - underexposure problems
The underexposed pictures are annoying but it can be easily solved. Just use the 4-way pad and add positive EV compensation. Then decided what works for you (0.3, 0.7 or 1.0, etc...)
Sep 08, 2005 | Pentax Optio S40 Digital Camera
Exposure problem
I've found that the *istD underexposes ( as it should metering 18% grey ) light subjects, or with light backgrounds. A white wall using TTL ( AF500ftz ) behind any subject it always turns grey! You need to manually adjust 1 stop over. With dark subjects, overexposing with out blowing out much. If your used to the metering from a PS digi cam the *istD takes a bit of getting used to.
Sep 08, 2005 | Pentax *ist D Digital Camera
Pictures are underexposed
When you are photographing scenes with mostly light objects (for example, snow, water, and sand), the picture is usually underexposed (darker than it really is). The camera meter registers the brightness of the scene and tries to set the camera lens and aperture for an exposure based on average brightness levels (18% reflectance) causing it to underexpose, as in the following picture. When you are photographing scenes with mostly dark objects (for example, shade, shadow, and overcast skies), and very few light objects, the camera may overexpose the image, causing it to be too light. If you have a flash on your camera, you can compensate by adding "fill flash" for some extra light. If your camera has an exposure compensation adjustment, you can increase or decrease the exposure to correct for these exposure problems. Increase the number to make the image lighter, and decrease the number to make the image darker. You may want to try a series of shots with different exposure compensation adjustments to get a feel for how much difference these adjustments make.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Canon EOS-20D Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
