Question about Kitchen Appliances - Others
Jml steam bee not heating although the on light is lighting up.
Toyota celica dash board red light light comes on looks like a pan with steam symbls coming outt steaming pan is it the breaks or catalatic converter heating up
There is no warning light for catalytic converter heating uo. Brake light usually is a exclamation mark inside a circle inside parentheses. What you are describing sounds more like a temperature warning light for the cooling system.
Nov 12, 2016 | Toyota Cars & Trucks
Steam mop not putting out steam although it is heating up
Well, if you have heat and there is water in it then this is one of two things. The delivery hose is clogged either too or from the heating unit or the heating coil is not getting hot enough. Look for dripping water that is not turning to steam while it is running. That would eliminate the clogged problem. Then you could look at the heating temperature at that point.
Jun 03, 2016 | Vacuums
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
Kitchen Appliances - Others Logo
199 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
