Question about Refrigerators
My kenmore Coldspot Mod# 106.53592300 had a burning smell this morning, the compressor makes a clicking sound, is this normal?
  • Refrigerators Master
  • 4,655 Answers
Most likely changing these parts in this photo=> 106.53592300 Compressor Area and Components
Picture # 13 is=> 4387835 Overload w/relay
The run capacitors in photo show two and I would have someone test them there is no reason to pay the prices listed when you can supplement a run capacitor very cheap at a refrigeration supply store locally. If you have question please ask, and please rate this solution, Thanks, Sea Breeze
Posted on Mar 22, 2011
    Champion:
  • 239 Answers
The compressor relay is likely faulty. It is mounted directly to the LH side of the compressor. YOu will need to replace it.
Kelly
My Kenmore Coldspot Mod 106.9651810 refrigerator start a loud buzzing noise.
Sounds like your relay to your compressor has failed, but before you start buying parts has your unit failed to cool? If so you may want to look into the overload to the compressor. If this has failed the unit will fail to cool. If not the issue please get me more information as to status, temperatures etc..
Thanks in advance, good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 03, 2013 | Refrigerators
My kenmore side by side refrigator has stopped cooling on both sides, you can here is click like the compressor is trying to run it cliks about 1 or 2 seconds then clicks again like on and off.sounds to me...
if the first three numbers are 106. on the model number it sounds like the start device on the compressor is bad,part number 8201799 and it's around 55 bucks,unplug the machine,remove the bottom back panel,you'll see the compressor,there will be a metal clip,pop it off with a screw driver and then slide the start device off the compressor,if it smells burnt or if you shake it and hear pieces rattling around it's cooked,also there's a timer in the fridge side,when you first open the freezer door the fan should blow,if it doesn't the timer could be stuck in defrost,with a screw driver you can turn the timer until it clicks and it will come out of defrost,if it starts then you have a bad timer that's stuck in defrost,but i'd put my money on the start device if the clicking is coming from the compressor area and it's not starting,let me know how you make out and as long as it's warm unplug it so you don't damage the pins on the compressor
Nov 03, 2010 | Refrigerators
Describe your Kenmore 53652 / 53654 / 53659 Side by Side Refrigerator Unit is not cooling. Stopped working after power outage
Kenmore Coldspot 106.53652300
I just fixed my neighbors fridge that suffered from a power surge. She explained that she smelt a burning smell in the kitchen and the next day the fridge and freezer were not cold. Of course she did not share the burnt smell part until after I discovered the starter relay and the capacitor were burnt on the compressor. She purchased the new starter kit and capacitor from a local supply company and while installing them I discovered the compressor fan was not running which also meant the compressor was not getting any power. I removed the screws that held the control panel on the fridge side (right side) and inspected the circuit board which I discovered a burnt trace on the board for the compressor control relay. I fixed the board by soldering a piece of solid core wire across it and it works great!
Make sure you shop around for your parts. The BIG local supplier here in Tulsa wanted $65 for the starter kit and $65 for the capacitor. We shopped around and found another supplier in Tulsa that sold them for $25 each and they were FSP parts!
Dec 15, 2009 | Kenmore 53652 / 53654 / 53659 Side by Side...
Smelt burning smell in the morning stopped cooling
I suspect the start relay burnt on the compressor. Now the compressor can not turn on. You need to repalce the relay.
Sep 04, 2009 | Kenmore 53542 / 53544 Side by Side...
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Kenmore coldspot 106.52234101 side by side. Freezer defrostet producing burning rubber smell. Any idea why. sam
sam_novik:
The compressor may have a short circuit. This might be the problem. The standard warranty is five years for this part. You can call Sears 1-800-4my-home, to get more info. If they come out to repair it, there might be a diagnostic fee ($70.00) and if it is the compressor, it should be fully covered.
Let me know what happens. Thank you, Binary Bob
Dec 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
379 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
