Question about Neff 24 in. S5456 Built-in Dishwasher
Won't Stop My dishwasher has only been used about four times but when I switch it on, it will go on an on for hours and hours until eventually we just have to switch it off. It doesn't dry the dishes just continously sprays water on them. The timer runs down but then just goes back up and starts again as though it keeps repeating the cycle.
  • Dickiedark Oct 11, 2008
    In the end we had to get an engineer out who told us there was a fault with the 'sensor' on the bottom of the dishwasher (underneath). As this wasn't working properly, the machine was just filling up with water, going into 'flood' mode and then draining.
    With regard to the continuous washing and not drying, we had our timer all set up wrong. We didn't have the 'heat' schedule set and we were pressing the wrong buttons to start it. We were told to press button 1 and 3 (on the right hand side of the LCD - as you look at it) simultaneously - the machine gives you a time of say 66 minutes, but that doesn't (apparently) necessarily mean the cycle will last 66 minutes. The machine itself will shorten/lengthen this time depending on how dirty the dishes are. The next time you set your machine up to wash, the timing will show up as how long the previous wash took. We have been using our dishwasher like this now for some weeks and everything seems to be working fine.
    I hope this helps you solve your problem. Good luck.
  • claimsaw May 11, 2010
    Does the water get hot? if not heater could be faulty.
  • 734 Answers
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is
cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher.
Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature
of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than
120 degrees Fahrenheit.
Posted on Dec 12, 2008
Code2 comes up in the manual it says the drain hose is too high
Sure, if the drain pump have worked four minutes, and the pressure switch has not been reset, then the dishwasher will shutdown all the loads, the alarm buzzer will ring for thirty seconds and the dispaly shows E2. After alarming the dishwasher pause for three minutes than drain water for 60 seconds.
Disconnect completely the dishwasher from power outlet, drain eventual water inside the dishwasher, wait 30 mins or so, then plug back machine into power socket.
If the Delonghi has still problem when you restart it, then probably the pressure switch or the acqua stop device, which start up and stop the drain pump, is probably faulty and need to be replaced.
Basically with codee2, if you get water floods in the dishwasher, is usually the pressure switch or the water inlet valve to be changed.
When no water or very scarce water comes inside the machine, then it is the pressure switch or the aqua-stop switch.
Start testing, and eventually changing the pressure switch , this is often the cause for such problem.
If this solution had been helpful, please take your time to click the accept solution button, otherwise fixya will reward the first post published, disregarding its content.
I will be grateful if you can rate the best solution
many thanks
Here is circuid diagram
Mar 17, 2008 | Kenmore 15129 Built-in Dishwasher
Tip
TGHK watch instructions
This is not for Tag Heuer, it's for TGHK watches.Here's the procedure: Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode). Press the RESET switch to advance to the function you want to change (e.g. hours). Press the START switch to increment the hour to the correct time. Press the RESET switch to advance to minutes and, again, increment the setting using the START switch. (Hold the switch down to advance the numbers rapidly.) When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display. To set the ALARM: Press the MODE switch to display the alarm function. Press RESET once to see the hours blinking. Press the START/STOP switch to advance to the desired hour. Press RESET to advance to the minutes and set the minutes using the START/STOP switch. Press the RE#SET switch. The time will stop blinking. Set the alarm sound for either ALARM or CHIME using the START/STOP switch. Press MODE to return to the time display. To turn the ALARM off: Press the MODE switch to advance to the alarm mode. Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off. Press MODE to return to the time display.
on Mar 18, 2010 | Watches
I have a lg dishwasher and it ran for an hour and a half and then displayed E1 on it. Then, it would not stop running and wouldnt even turn off so i had to turn it off by the breaker. any solutions?
(1) The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
(2) The float switch actuates in order to prevent the dishwasher from overflowing. If the float switch is defective or stuck, it might not stop the dishwasher from overflowing. If the float switch is defective, replace it.
One would need the model number of your machine.
Dec 31, 2015 | LG Dishwashers
Techwood TV won't turn on
no you just need a new power supply and mainboard in this unit!
Jan 21, 2013 | Televison & Video
Electrolux dishwasher
Hello - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 05, 2012 | Electrolux 24 in. ESL4125 Dishwasher
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Timex 1440 sports WR50M
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears.
2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing.
3. Use StART/Stop to choose among seconds, hours, and minutes, and
4. Use ADJUST to increase the selected number
5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Mar 30, 2008 | Timex 1440 Nylon watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Neff 24 in. S5456 Built-in Dishwasher Logo
481 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
