Question about Frigidaire FTF2140FS Front Load Washer / Dryer
Mdl#FTF2140ES washer will not start, door lock light will not light up. Machine will not run diagnostic for codes. Used multimeter on door lock assem. it is fine.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Make sure the controls are not locked. There is a button that you will have to hold to unlock...it will have a padlock icon by it probably.
Kelly
Posted on Mar 22, 2011
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
FTF2140ES won't spin
How old is the machine ?
if about 3years old check carbon brushers
Dec 14, 2013 | Frigidaire FTF2140ES Stacking Front Load...
Replaced CCU, Sears washer still will not run
Suggestion: Unplug washer from mains. Open up the machine, disconnect and refit all connectors with wires one by one. Could be some loose connection somewhere. Also helps in the long run
Click if helped.
Mar 29, 2013 | Washing Machines
F26 code comes up when i try to start washer; won't allow me to start machine. What can i do to solve this?
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Jul 07, 2010 | Kenmore HE3T Washer
Affinity LTF7000ES door not staying locked
unplug the washer and wait 5 minutes before plugging it in again!
this resets the system. If this does not work then you may have a faulty door lock, latch, or switch!
An need hands on service on location
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 31, 2008 | Frigidaire Affinity ATF7000E Front Load...
Maytag MAF1300AAW Error code 4. The machine starts to fill then drains which is repeated several times before eror code 4 appears.
Hi this searstechtoo I did some research on similar american models and will paste what I found for you.
Will Not Lock
• Door not all the way closed or not properly
aligned. Possible laundry load is too large to
close door.
• Place washer into Service Mode and check for
diagnostic codes 4 &18.
• Perform Board Output Test. Check door lock
system.
• Check electrical connections at lock switch
assembly and machine control board (CN2).
Cn2 is a thermistor used in a wax motor to control the lock and unlock feature of the door.
I would start at the lock and trace the wires then unplug and replug them.
Thanks SearsTechToo
Oct 04, 2008 | Maytag Washing Machines
Frigidaire FTF2140FS Front Load Washer / Dryer Logo
212 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
