Question about Invicta Subaqua Noma Iii S
I have a SAN III model 4572. Starting/stoping chrono is fine. The min/hr subdial at the 9 o'clock position is frozen. Currently, the minute hand is stuck at the 2 o'clock position. When I press the reset at the 4 o'clock position all hands go back to the top, but the red hands at the 9 o'clock subdial do not do anything. Any suggestions?
  • 29 Answers
SOURCE: Invicta Ocean Ghost Chrono Model# 2636
Did you recently have a battery changed. A lot of times on chronos when the battery is changed the battery has to be short circuited to the AC. Which is done by taking tweezers. & touching the positive part of the battery to the part of the watch marked AC. Then try to pull the crown all the way out to time setting position press the top rt button & the second should move keep moving until it lines up with zero. If you haven't had the battery changed try what I told you to do with the crown & the top right button.
Posted on Mar 13, 2008
SOURCE: I can't figure out how to adjust the offset chronograph
This is to adjust the seconds hand or minutes hand for the chronograph. Pull the crown out either one click or two ... depending on the models. Squeeze and hold the top and bottom buttons at the same time (timer stop and reset buttons). Hold down together for 2+ seconds. The chronograph hands should reset by spinning around and stopping at 0. If the don't stop right at zero, you can now adjust where they stop. Leave the crown where it is in that same position out. Press the top chronograph button and hold it down for fast movement or short presses for fine movement to adjust til it stops at the top. This will adjust where the seconds hand stops. Then click the bottom chrono button once. Repeat what you did with the top chrono button and it should allow you to fine tune the position for the next dial, and so on. When you are done, press the crown back in all the way to the normal position.
Posted on Jul 07, 2009
  • 183 Answers
SOURCE: Have an Invicta Lefty Quartz Chronograph. The
Actually the sweep arm can be set to 0 and will probably have to be every time you have the battery replaced. To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it. Make sure to set the right time and replace the crown in the time position.
Great watch!!
Posted on Sep 18, 2009
  • 56 Answers
SOURCE: The large second hand for use in the chrono mode
pull out the crown to either the 1st or 2nd position and use the top and bottom buttons to zero out. please rate my solution
Posted on Oct 10, 2009
Testimonial: "Thanks. Awesome correct solution in minutes and free!!"
escapement
  • 2334 Answers
SOURCE: On a Invicta Men's Off-Shore Russian Diver Quartz
It isn't a fault and can be adjusted. Follow this link and find out how to.... http://www.invictawatch.com/ Point at COLLECTIONS and click on INSTRUCTION MANUAL. If you don't know which one of movement makes you have, try both (RONDA first, then MIYOTA). When sorted with type of movement, check how to reset chronograph to 0 (zero).
Rate me, please.
Posted on Jan 12, 2010
Testimonial: "Thank you so much, now i dont have to mail it back in and i know how to actually work it now, your awesome! "
CHRONOTECH ACTIVE CT7096M/18M MEN'S WATCH
If it says "automatic" "kinetic" or "mechanical" you need to wind it or wear it to run. If it says "solar" or something of the sort, it needs light. If It says quartz or simply, nothing at all, then you just need a battery. If the watch is a chrono, you might see 3 subdials and one of the smaller subdials with the small hand should be running. The small (usually at the 6 o clock) is the second hand.
Dec 25, 2013 | Watches
Can I reset the second hand and the lower dial on the watch?
long answer with info given, but this is what will explain it all that small subdial at the 6 area is the second hand that runs at all times, large red hand is stop watch seconds,allso on the center pin is the minute hand for stopwatch 2 o,clock subdial is tenths of a second, for stop watch 10 o,clock subdial is hours for stop watch
Jul 09, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
May 21, 2009 | Invicta Dragon Lupah 2093 Wrist Watch
Watch not working
Synchronization of the chronograph hand do not affect any watch movement to work properly and it is ment for correct time measuring only.
If your watch does not work properly there is some kind of fault in it and you will need to see a watchmaker to diagnoze it.
Feb 15, 2009 | Cartier Roadster W62019X6 Wrist Watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
How do I use my watch???
I also own a PRS200. The two buttons on the right and top two subdials are for the chronometer function.
The top right button starts and stops the chronometer function: First press starts the chrono. Second press freezes/stops it, so you can record your time. Third press resets the chrono.
The bottom button is for the lap function: on the first press, it freezes the chrono in order for you to be able to record your "lap time", but keeps the chrono running in the background (you don't see this, it's the movement that does this mechanically). When you press it a second time, it jumps back to the running chrono time. You can then press it again to get another lap time, and so on...
In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
Feb 23, 2008 | Tissot PRS 200 Wrist Watch
Luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Jan 02, 2008 | Luminox Field 821 wristwatch
Tissot prs200
I also own a PRS200. The sub dial at the top left shows the minute count when you use the chronometer function. In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
Dec 23, 2007 | Tissot PRS 200 Wrist Watch
Invicta Subaqua Noma Iii S Logo
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you an Invicta Watch Expert? Answer questions, earn points and help others
