Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
I cannot install my Epson workforce 600 and get it to accept the IP address for my cisco linksys E1000 router.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 143 Answers
I actually own a workforce 600 printer... they are nice for photos... anyway, the following solution only applies if your router is configured as a DHCP Server... This is the default setting, so if you don't know, then it is probably is configured as a DHCP Server. So, First, plug your printer directly into the router (wired connection) Then, load all drivers and software onto your computer. There will be one program in particular that you want to use. It is called "EpsonNet Config". Open that program (it is located in start---> all Programs--->EpsonNet---> EpsonNet Config Vx ) If your printer does not show up, you must verify your network settings on the printer (First make sure your wireless is disabled in Setup ----> Network settings --->Wireless LAN setup ----> Disable.... Then, Setup ----> Network settings ---> general network setup ------> "Yes" ---> press"ok"----> "Auto" ---->press"ok"---->"yes") Now, go back to EpsonNet Config on your computer and click refresh (upper left hand corner). When your printer shows up, double click on it. In the left pane click on network---> basic (wireless). In the right pane, click enable wireless LAN, then type in your SSID (routers name). DO NOT CLICK TRANSMIT YET. Then, in the left pane, click "network ----> security". In the right pane, put in the appropriate security level and key for your router. This information you would have configured when you setup your router. Now... click transmit then "ok". Wait for the settings to transmit 100%. now you can remove the network cable... verify that EpsonNet Config still can see the printer. and you are good to go. I hope this helps.
Livingmentor
Posted on Mar 22, 2011
How to fix error 322 on linksys wag120n
getting ip starting 169.x.x.x ... cannot access router config page. Even reset don't work
Dec 03, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Why wont my computer obtain its ip address
How many computers do you have in the network?
How many are not able to access the Internet or IP address?
If only one computer is not able to access the Internet then you can try assigning a static IP address on the computer and see if you can access the Internet.
If all the computers are not able to get IP address from the router then I think you should try to reset and upgrade the firmware on the router.
See How to upgrade firmware on Linksys router.
Mar 11, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Signel from router is weak can i turn it up
If so it will be through the router interface. Try to look in here
Default IP address: 192.168.1.1 Alternate Admin URL: http://my.e1000/ Default admin username: <blank> Default admin password: admin
Feb 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I need a static ip address how do i get one
Static IP address should come from them, some of our service providers give paid static P addresses to customer, you can check it from them for they are the one who have control providing ip address either static or dynamic.
Dec 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Linksys E1000 Wireless Router limited or no connectivity
What is the operating system on your computer?
Are you trying to connect to the wireless network?
on Windows XP computer you will get this message when the computer is not able to connect to the wireless network.
There are 2 reasons. You might have entered incorrect password or your computer is not getting IP address.
Read Limited or no connectivity
Oct 03, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How do I set up password for my cisco wifi?
If you connect to your router via the IP address you can make many changes, such as the password.
The default IP for your e1000 should be 192.168.1.1
If you go to this address with your web browser, you can then log in as the admin and change the password.
The default password should be admin (all lowercase).
Hope this works for you!
Sep 19, 2011 | Cisco Linksys Wirelessn Router Black...
I use a Cisco Wireless-N Router E1000 to connect wirteless laptop. The Cisco is connected to the main router to internet. IP internet router is 192.168.1.254 The Cisco router is 192.168.1.1 The laptop...
I'm confident that having both routers distributing the same subnet is causing a conflict.
You should change the Cisco router to 192.168.2.1. and let it deliver IP addresses by DHCP.
That should do the trick.
May 13, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
How to secure the internet? and what is the IP
The default gateway for Linksys is 192.168.1.1 and to change the security code for wireless, go to the "Security" tab.
Thank you for choosing FixYa!
Apr 23, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My Linksys E1000 is constantly resetting itself to its factory default. It will display my old Wireless Server but that will not give any valid IP addresses when I connect to it. How can I get my router to...
Hi Brian, I haven't had this specific problem, but I did have trouble with my E1000 losing connection often. What seemed to solve this for me was to update the Firmware. Have you tried that? You can go to Cisco's homepage and download the proper firmware for your router by following this link http://goo.gl/Ildp6. You will have to select your hardware version which you can tell by looking at the tags on the bottom of your router.
Jan 15, 2011 | Cisco Linksys Wirelessn Router Black...
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
608 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
