Question about Dell Inspiron 6000 Notebook
Wshtcpip.dll error message
I hadn't used my laptop for a couple of months - Dell Inspiron 6000 with XP Media Centre, with all the updates, etc. When I turned it on, I keep getting error message relating to the above wshtcpip.dll, in that it is not a valid image. In addition, I am now unable to connect to the internet.
I have a home network, a Dell desktop connected by cable to a router and the laptop by wireless. The desktop connects fine, and I can see files on each computer from the other, so the network is working. I just cannot connect to the internet from the laptop.
If you run the Diagnose Connection Problems from inside IE7, it reports that base ISP entries are missing from the winsock catalogue, and a reset is required??
Help, anyone??
Run command promt as admin
then paste this command
sfc /SCANFILE="C:\Windows\System32\wshtcpip.dll"
It must restore if there any error
Posted on Jun 07, 2010
    Genius:
  • 2,028 Answers
Run a system restore. You may need to go back two or three restore points before it fixes the problem, but the restore should do the trick. Try this, let me know, and if the problem persists, then we'll try a different approach.
Posted on Aug 05, 2008
Says windows root>\system32\hal.dll. is missing or corrupt, can't use laptop Please advise, regards Jason
some system on your windows has corrupted, it caused by a virus or bad disk
you need to restore your system to fix this issue
if your laptop build in windows xp and you have a restore disk just follow these steps
1. turn on your notebook
2.quickly press ctr and f11 simultaneously
3. click restore when "Dell PC restore" message appears
4.click confirm (it means you will lost all data in drive which contains your old operation system)
5.wait and click finish when the process of restore finish
if your laptop build in windows vista you can follow these steps
1. turn on your laptop
2. quickly press f8
3. when "Advance Boot Menu" message appears just click repair
4. select language and click next
5. log in and click ok
6. click dell factory restore and click next
7. click yes on the box "format hard drive and restore the system"
8. when the process finish click finish
if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Jun 06, 2011 | Dell Inspiron 6000 Notebook
My girlfriend has a Dell Inspiron 6000. When we try to boot it up, it will start the process and then stop before windows xp comes on, displaying a flashing underline in the upper left of the screen and...
have you tried replacing the hard drive and then reinstall the xp i have encountered sam problems with dell laptops, plus clean out your fan after you do this there should be better performance.ley me know how this works out for you..
Apr 15, 2011 | Dell Inspiron 6000 Notebook
Why wont my inspiron dell laptop feed internet
check if ethernet card is detected in device manager or not if yes
update the drivers fro www.support.dell.com
if still dosent work try to use external ethernet card.
Apr 01, 2010 | Dell INSPIRON 6000 CENTRINO...
Blue screen on Dell Inspiron 6000 Laptop
OUCH... Might need a new harddrive or motherboard. Does it even let you go into the bios? Maybe you can do a full reinstall to save you the dough.
Jan 06, 2010 | Dell INSPIRON 6000 CENTRINO...
Possess dell inspiron 6000 centino wireless, need drivers and xp
You can contact Dell Technical Support and see if they will send you a new XP CD. All the drivers can be downloaded at Support.dell.com for that system. If you can't get Dell to replace the CD, try Ebay. Here is an Example:
http://cgi.ebay.com/Reinstallation-Dell-CD-w-MS-OS-XP-Pro-SP2_W0QQitemZ300352622860QQcmdZViewItemQQptZUS_Software?hash=item45ee69510c&_trksid=p3286.c0.m14#ht_500wt_1182
Sep 30, 2009 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 6000 laptop won't boot up
Pleae reboot your system and when you see the Dell logo , press the F12 key a couple of times .
In the menu, select only HDD diagnostics and post the results back . If the harddrive fails, then the only solution would be to replace the same. If the hardrive passes , we may be able tp fix the system
Thanks
proton
May 31, 2009 | Dell Inspiron 6000 Notebook
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
782 people viewed this question
Alun Cox
