The screen appears to be Dirty, is there a removable cover?
  • 643 Answers
No removable cover clean with lint free rag and luke warm water. NO cleaning products or paper towels, may scratch the screen.
Posted on Mar 22, 2011
'close your front cover' appear on the screen
jst close the frnt cover of prntr or smtng or remove us cables connected to it
Mar 21, 2012 | Canon GP300-405 PS Ver 1.0
Have closed cover properly. cover vup sign still there.
Try to follow the steps below to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on and comes back with the error on the display screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new cartridge.
  9. If no error appears, try to print again to verify that the problem is fixed.
Oct 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
Under the inside cover (right side) i see what appears to be burning when operating unit - is there something behind that removable cover that can be replaced or repaired to solve the...
Replace the cover as it is obviously dirty with carbonised food particles. Don't use it without a new Wave Guide Cover or permanent damage to the magnetron/aerial may result.
Dec 17, 2010 | Amana AMV1162 Microwave Oven
The bottom of the screen has transparent green blotches
This model has a geometry mirror that is lies in the front of the cabinet. It is dirty and needs cleaned. Remove the middle front plastic cover, between the screen frame and speaker cover. Remover the screen frame, disconnecting the harness (4 screws are behing that middle cover ;). Clean the mirror and reassemble. Wipe the lens while you are in there and do not touch the big mirror... you'll really have a mess if you do. Also, use caution not to put pressure on that little mirror as you clean it, you'll mess up the geometry and end up with a trapezoidal picture.
Mar 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Horizontal lines across whole screen
Bad inverter, or a dirty one. Remove the power cable and battery, then take apart the screen bezel, or casing. Remove the LCD by unhooking it. Disconnect the inverter. Clean it. Reconnect it. Fixed.
Feb 01, 2010 | ASUS Eee 1000H Notebook
B4600 pane screen says I have an exit jam and to open upper cover and remove. THERE IS NO JAM!!
Open that cover look for the sensor it could be a dirty sensor or the spring came loose that flips the sensor back into position.
Oct 30, 2009 | OKI B4600 Laser Printer
How can I remove the back cover on a SAMSUNG HCR5245W, I need access to clean the mirror and projectors. Already removed all screws. The back cover appears to be made of two parts but I cannot split. From...
Hi my name is Roety,
I can help you with your issue ,
Leave the top rear half bolted on.
Remove the rear edge screws to remove the front half, then remove the front lower section by taking out the few rear screws holding it, then there is another piece just below the screen that pulls off revealing the last few screws holding the top front screen section in the front lower edge.  Take the front off, cleaning the mirror and lens will help, but I'll bet the fluid is dirty inside the blue and green tubes, look into the tubes with the TV on to check.
best of luck
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 19, 2009 | Samsung HC-R5245W 52" HDTV
I own a cannon 2800 copier and an error code of E000019-000 appeared what does tht mean?
waste toner is full or dirty window on bottle on the left side of copier then lower left cover 1 screw holds cover in. remove screw rmove cover pull out waste bottle empty the bottle and clean the 2 circle windows on the top of the bottle replace all turn copier off then on that should do it
Sep 11, 2009 | Canon Office Equipment & Supplies
Inside screen seems to be getting dirty
I had the same problem until I removed the screen and cleaned the front mirror with a static feather duster. First, turn OFF power. Second, remove screws on rear at top and on both sides of the screen. Third, remove speaker grill. Fourth, remove screws on each side of the screen where screen meets the speaker area. Fifth, remove two screws in center area of speaker area under screen. Sixth, lift screen up and away from set housing and use a duster with a two to three extension and GENTLY wipe the noticeable dust layer from the front tilted mirror located behind the screen at bottom of screen. Seventh, do everything in the REVERSE and you're done. If you need to replace the lamp, now's a good time to do so. Also you should clean the dust filter located behind an access door on the rear (right hand side as your are looking at the rear) with a handheld type of vacuum device.
After I completed ALL of the above procedures my WD-62525 was better than I remember. I bought it in 2005 and the picture quality has never looked so good.
The screen is as light as a feather but 62" is awkward. It is recommended you use another person to hold the screen but I work best alone and it was a breeze.
GOOD LUCK.
Dec 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
