Question about Rowenta DZ1700 Iron
Rust colored steam that stains clothing ironed
  • Rowenta Master
  • 43,501 Answers
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Posted on Apr 02, 2011
Swan steam iron 2200w
To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the lime scale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any residual vinegar etc. Turn off and unplug the iron and pour out the remaining water. Descale completed.
To clean the base (soleplate) first, make sure your iron is completely cool before cleaning.
There are a number of things to remove various stains. For general stains rub the bottom of the iron with table salt and a soft damp cloth. For marks left by limescale (a powderey white) use undiluted white vinegar on a soft cloth. Some stubborn stains can be removed with a paste made from baking soda and water. What ever you use make sure you rinse and wipe the soleplate dry before using again. Never under any circumstances use a metal scouring pad or wire wool type cleaner, this will scratch, mark, and probably damage the soleplate beyond repair.
Nov 30, 2013 | Irons
How do I descale my iron
Oct 29, 2013 | Irons
Shoots out through the steam vents and sains clothing
The symptoms you describe are indicative of mineral buildup in your iron. The instructions probably say to use distilled water in the iron and may include a procedure for removing mineral deposits
Jan 14, 2013 | Rowenta DG-980 Iron
Our iron keeps shutting off and on. It then spurts out brown liquid from the iron. It is on my wall and it stains our clothes
the brown liquid is rust from leaving the water in the iron. Always dump the water out when you are done ironing. You need to run a descaler through it. you can purchase descaler online. The shutting off and on could be a loose wire.
Aug 11, 2010 | Euro-Pro Shark GI490 Iron
Iron Blck & Decker: model D2020. I would like to clean my iron because is stared to stain all my clothes. I just open the white plastic parte on the back, but i dont see any other screws or how to get...
No need to dismantle the iron. Just fill it with a 50/50 white vinegar/distilled water solution and allow the iron to expel all of it as steam. Rinse with distilled water and allow to pass as steam. If you use distilled water from now on, you should no longer have staining problems. Hope this helps!
Jul 18, 2010 | Black & Decker D2020 Iron
Tefal steam iron cleaning
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Apr 24, 2010 | Tefal UltraGlide Easycord FV4256 Iron
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
Simac Stirelli 9000 steam iron spews rusty steam and smells like burnt apples
Your steam iron has been filled with 'tap' water that may have been contaminated (thus the smell). Rust develops more rapidely in Steam Iron chambers when distilled water is not used: to clean the 'enclosure' of the steam iron from rust and smell, over a sink or outdoor, fill 'cold iron' with a 50/50 water/vinegar and a teaspoon of bicarb, let it stand for about 10 mins, then turn the iron on and let it steam the mixture out while shaking the iron gently (DO NOT BURN YOURSELF! STEAM IS HOTER THAN BOILED WATER!). Refill and Steam flush again with Clean water (distilled preferred). Repeat the steps until the rust has been completely dissolved (check by steam ironing on clean pieces of disposible kitchen paper towel. Use the Power steam or Flush function of the Iron if available. Hope it helps!
Dec 17, 2009 | Irons
Rowenta DZ1700 Iron Logo
509 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
