Question about LG WM2487H Front Load Washer
LG Tromm washing machine model WM2487HWM has an error code. First letter looks like a capital E without the top horizontal line. second letter is an E
  • steelskyway Oct 20, 2013
    This code is for the thirmistor. The part is bad and needs replacement.
    Brigadier General:
  • 6,277 Answers
That's 'te' standing for temperature error/ heating error. Before you call an engineer try emptying the washer then pouring a couple of kettles of boiling water into the drum and leaving for 30 minutes then see. Another thing is to empty a couple of packets of limescale remover into the drum together with a couple of kettles of boiling water (again!) and leaving overnight. It possibly needs de-scaling anyway ;-0) If these fail it will be an engineer call, sorry ;-0(
Good luck, John C
Posted on Mar 23, 2011
Read error codes on LG TROMM WM1614CW
The PDF Owner's Manual from Product Support contains error codes. It is not the exact same model but frequently the same product line uses similar components with similar error codes. Its worth a look anyway. Hope this helps.
Jan 03, 2015 | LG WM Washing Machines
I have a LG WM2487HWM front load steaming washer. It has had the regular odor/mildew/mold problem from almost the first month. Recently the machine has struggled with draining all the water. Now it leaves...
Leave the door open for 24 hrs after wash for Odor problem. You need to clean the rubber gasket around the door with 1:4 Bleach/Water (It's Fun!...Not!) First though. Not draining? You need a New Drain Pump! Go to YouTube and place LG Washer not draining. They have 20 videos on how to repair...Very Easy!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
I have an LG2455HW which displays the control error code. i have the machine open from the top and back. i can not see any fuse in the control board and am unsure what this code means. The error is the...
that's a bad thermisitor the code is tE that's a lower case t and a capital E part number 6322FR2046C it's down at the bottom of the tub to the right of the heater.go here to see part
https://www.searspartsdirect.com/part-number/6322FR2046C/0026/795.html?modelNumber=WM2277HW&categoryName=Residential%20Washers&brandName=LG
Nov 10, 2017 | LG WM-2277HW Front Load Washer
STARTING PROBLEM OF FRONTLOAD WASHINGMACHINE
If the error code is DE, then you need the door lock assembly.
I will need the full model number to find the right part number.
Mar 13, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg tromm washing machine has an error code LE
Empty Washer and unplug. Hold the start button (arrow with two lines) for 10 seconds. Plug back in and put on the Rinse and Spin cycle (right hand side) I went ahead and ran that cylce (31 minutes with some bleach) and all worked well.
If problem persists call CSR. 800-243-0000
Jul 14, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
We have an LG Tromm WM2487HWM that has an upside down f and e error code. The machine will sometimes start and then quit after about a minute into the run. Unplugging and replugging in does not seem to...
We have the same problem on our washer - same model as yours. Home Depot has the warranty on this thank goodness we bought it. They replaced the motor and water pump - didn't fix the problem longer than a month. A new repairman has come out and says we need a new heater and thermistor (whatever that is - I checked - not a thermostat but possibly related??) Approx a $300 fix. Good luck.
Jun 20, 2009 | LG Washing Machines
Need Directions on how to use machine
Hello maemaez4,
I will put a link below which will take you to a web page with a downloadable PDF owners manual for the Tromm. You will have 4 different options,( WM2487HRM, WM2487HRMA, WM2487HWM, WM2487HWMA ) just click on the model of the one you have and it will give you the correct manual. Hope this is what you were looking for.
http://us.lge.com/support/download/search/1000000376_EN_OM_WM2487.jhtml
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
May 19, 2009 | LG Washing Machines
My washing machine
Clean the drain filter out. Then while the filter is out, take a flashlight and look into the filter hole. We had this problem and discovered a metal bottle top lodged in the hole which goes to the pump. Removed the bottle top easily and the machine works fine.
Nov 14, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2487H Front Load Washer Logo
749 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
